ACL doubt
palani2010
Can someone please explain what is this ACL Referring
permit tcp any range 0 65535 any eq www
Hello
"permit tcp any range 0 65535 any eq www"
 permits  tcp traffic from any source in range the port range of 0 65535  to any destination equal to tcp 80
Kind Regards
Paul
5 Replies 5
Joseph W. Doherty
Apparently, it matches any TCP traffic with a destination port of 80.
Joseph got to this before I did and I agree with his answer. I would also say that while the acl statement is correct in its syntax that it unnecessarily complex. the statement "range 0 65535" simply restates what is the default behavior and so is redundant.
Rick
I had thought to mention that, the ACE's unnecessary complexity, and decided not, but it's probably worthwhile Rick did, as may confuse because it's, as he noted, redundant.
Depending on the platform, actually entering that statement, as posted, the platform might remove the range portion.
Hello
Kind Regards
Paul
burhaans28
@palani2010
This ACL rule allows TCP traffic from any source IP (any) and any source port (range 0 65535) to any destination IP (any), but only if the destination port is 80 (HTTP), represented by eq www. In simple terms, it permits all HTTP traffic to flow unrestricted to any server, where permit allows the traffic, tcp specifies the protocol, and eq www targets the HTTP port.
Pls like and accept the post as helpful if this really helps you.
