ACL
kzhen
A router is running "c7200-advsecurityk9-mz.124-11.T.bin" We have few hundred ACLs in our router. Every time when adding one acl we need to delete first because there is deny any at the end. Is there any ways to be easier to manage those acl? just simply add one acl without deleting existing acl.
Edison Ortiz
And I just noticed another new behavior and you don't need to migrated to 'named' ACLs.
Here is my current ACL:
access-list 101 permit ip host 1.1.1.1 host 2.2.2.2
access-list 101 permit ip host 1.1.1.1 host 3.3.3.3
access-list 101 permit ip host 1.1.1.1 host 4.4.4.4
access-list 101 deny ip any any
Now, I want to add an additional entry before deny ip any any....
Rack1R4#show ip access-list
Extended IP access list 101
10 permit ip host 1.1.1.1 host 2.2.2.2
20 permit ip host 1.1.1.1 host 3.3.3.3
25 permit ip host 1.1.1.1 host 4.4.4.4
30 deny ip any any
Rack1R4#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Rack1R4(config)#ip access-list extended 101
Rack1R4(config-ext-nacl)#26 permit ip host 1.1.1.1 host 5.5.5.5
Rack1R4(config-ext-nacl)#do show run | sec 101
access-list 101 permit ip host 1.1.1.1 host 5.5.5.5
__
Edison.
5 Replies 5
Edison Ortiz
instead of using 'numbered' ACLs, you should migrate to 'named' ACLs.
Example, here is an 'named' ACL with a deny at the end:
sh run | sec NETPRO
ip access-list extended NETPRO
deny ip any any
If I wanted to insert an entry before the deny any any...
Rack1R4#show ip access-lists NETPRO
Extended IP access list NETPRO
30 deny ip any any
Rack1R4#conf t
Rack1R4(config)#ip access-list extended NETPRO
Rack1R4(config-ext-nacl)#25 permit ip host 1.1.1.1 host 4.4.4.4
Rack1R4(config-ext-nacl)#do show run | sec NETPRO
deny ip any any
HTH,
__
Edison.
You should be able to delete the entries in the ACL by using sequence #s without having to delete the whole ACL modify and put it back.
Here you go.
R1#show access-list 100
Extended IP access list 100
10 permit ip 172.16.1.0 0.0.0.255 150.50.0.0 0.0.255.255 (2 matches)
20 permit ip 192.168.1.0 0.0.0.255 150.50.0.0 0.0.255.255
R1#config t
R1(config)#ip access-list ext 100
R1(config-ext-nacl)#no 20
R1(config-ext-nacl)#end
Sundar
Edit: I just noticed Edison responded to this as well. It wasn't possible a while ago before but you can use numbered ACL to remove or add sequence #s for sometime now.
Edison Ortiz
30 deny ip any any
Rack1R4#conf t
__
Edison.
Edison,
it really helps. How can you get those info about ACL?
thanks,
Ken
Ken,
The first iteration I learned during my CCNP studies and on the job.
The last iteration I learned it today while playing with my gear for this very same post :)
Thanks for the rating and good luck !
