ACLs missing after reload the switch
HCL Support
We had an power shutdown activity last week, due to which one of the core switch was turned off and ON .
After the core switch was turned ON, we had found some of the ACLs missing which were bounded in VLANs.
Please note that we had given write command before this power shutdown activity.
We need to find the root cause for the same.
Let us know what are the information/command outputs, you  required from our side to take it up further.
Switch Model-WS-CISCO-6509-E.
Akhil
paolo bevilacqua
Update IOS, and check again.
Hi Akhil,
can you pls share the root cause (if resolved) of that issue...?
KodandaRao,
davidjknapp
Akhil, As a sure fire way to ensure the wr is issued and a way to provide security against a corrupt config file you can use the archive command
something like this.
archive
   path %
   write-memory
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! and optionally
   time-period %
