222
Active/Active, multi homed BGP, dual router , HSRP config
Hello All,
I have
Active/Active, multi homed BGP, dual router , HSRP config on LAN,  Now I want to  change the HSRP priority to avoid one extra hop in case one ISP fails, I want to use the EEM feature instead of IP SLA  which I am currently using But It’s the first time I am trying to use this,
Can you guys help me to find whether my EEM config is good enough to achieve what I am trying to achieve or I need to make some changes to this config
ISP1
event manager applet track-bgp-down
event syslog pattern "%BGP-5-ADJCHANGE: neighbor 10.10.10.17 Down BGP Notification sent"
action 1.0 syslog priority critical msg "EBGP Session to peer is down"
action 2.0 cli command "enable"
action 3.0 cli command "conifg t"
action 4.0 cli command "FastEthernet0/1.90"
action 5.0 cli command " standby 12 priority 85 "
action 6.0 cli command "end"
event manager applet track-bgp-up
event syslog pattern "%BGP-5-ADJCHANGE: neighbor 10.10.10.17 Up"
action 1.0 syslog priority critical msg "EBGP Session to peer is up"
action 5.0 cli command " standby 12 priority 110 "
ISP2
event syslog pattern "%BGP-5-ADJCHANGE: neighbor 20.20.20.41 Down BGP Notification sent"
action 5.0 cli command " standby 11 priority 85 "
event syslog pattern "%BGP-5-ADJCHANGE: neighbor 20.20.20.41 Up"
action 4.0 cli command "interface FastEthernet0/1.90"
action 5.0 cli command " standby 11 priority 110 "
Jagdev
1 ACCEPTED SOLUTION
Enthusiast
You would probably get a better response to this one in the EEM scripting forum.
1 REPLY 1
Enthusiast
Content for Community-Ad
August's Community Spotlight Awards
