Add a stack switch
zebranutz80
I have 2 switches connected via Stack Cables. The first switch is running c3750-ipbasek9-mz.122-35.SE5.bin. The second is not running an IOS other than the bootloader. Can I automatically upgrade the second switch from the first?
John Blakley
By default it tries to upgrade automatically, but mine didn't work. I just did this over the weekend, but what I ended up having to do was copy from the first switch to my sixth after deleting the IOS on the sixth switch:
del flash6:/name.of.bin
copy flash1:/name.of.bin flash6:
I then reloaded the 6th switch:
reload slot 6
It came up fine without the "VERSION MISMATCH"
HTH,
John
HTH, John *** Please rate all useful posts ***
I thought it automatically upgraded. I think what happened is that I power cycled the 2nd switch while it was in the middle upgrading. I have an "Upgrade" folder on the 2nd switch now. When I try to boot to the .bin file contained in the folder, it gives me an error. I will delete the .bin file, reboot, and start over.
Unfortunately, I work at a hospital and will have to do this late tonight.
