03-23-2020 08:11 AM
Hello
i have router ASR1006
with paltform 1/0 BUILT-IN-6TGE ok 1w1d
i make ten1/0/1 , ten1/0/2 , ten1/0/3 as Port-Channel 1 and everything working fine
i create same subinterface for example
interface po1.9 encapsulation dot1Q 9 ip address X.X.X.X X.X.X.X !
after that i try to add ten 1/0/0 to port-channel 1
by
int ten1/0/0 channel-group 1
but i get message error
% Error: Interface has subinterface configured
so what i can do ? remove a all sub-interface from port-channel then add the ten1/0/0 then add again a sub-interface
or what ?
Solved! Go to Solution.
03-23-2020 08:21 AM
- YES
M.
03-23-2020 08:21 AM
- YES
M.
03-23-2020 08:23 AM
