10-30-2017 04:30 PM - edited 03-05-2019 09:24 AM
Hi all, I just upgraded the IOS on a test 1941 router, from 15.3(3)M7 to 15.5(3)M6 and found that the command "ip nbar custom" isn't available. Anyone else hit this?
Also, just wondering if there is a workaround or best practice to overcome this?
Output below for your reference:
1941-Router#show clock
09:08:42.057 EST Tue Oct 31 2017
1941-Router#
1941-Router#
1941-Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
1941-Router(config)#
1941-Router(config)#ip nbar ?
http-services Enable HTTP services (URL to use is
/flash/nbar2/home.html)
pdlm PDL (protocol description language) Module -
DEPRECATED!
protocol-pack Protocol Pack
protocol-pack-auto-update Auto Protocol Pack update config
1941-Router(config)#ip nbar custom x00_DNS udp 53
% Invalid input detected at '^' marker.
1941-Router(config)#ip nbar custom ?
% Unrecognized command
1941-Router(config)#end
1941-Router#
1941-Router#
1941-Router#show ver | in 15.
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.5(3)M6, RELEASE SOFTWARE (fc2)
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
System image file is "flash:c1900-universalk9-mz.SPA.155-3.M6.bin"
Cisco CISCO1941/K9 (revision 1.0) with 491520K/32768K bytes of memory.
1941-Router#
1941-Router#
1941-Router#
09:10:05.286 EST Tue Oct 31 2017
1941-Router#
1941-Router#
1941-Router#show ip nbar version
NBAR software version: 23
NBAR minimum backward compatible version: 21
Loaded Protocol Pack(s):
Name: Standard Protocol Pack
Version: 14.0
Publisher: Cisco Systems Inc.
NBAR Engine Version: 23
State: Active
1941-Router#
Ben
Solved! Go to Solution.
10-30-2017 08:04 PM
Hi Ben
Could you please let me know what license do you have on the router? I think from 15.5, only when you need to have datak9 license for the custom protocols to work with nbar.
Hope this information helps.
10-30-2017 08:04 PM
Hi Ben
11-01-2017 04:58 PM
Thanks Vinit! The router has ipbase. Might go back to the latest 15.4M then.
