01-05-2014 03:34 AM - edited 03-04-2019 09:59 PM
I've got a 2921 router.
I'm using ge0/1 as a WAN connection over a leased line.
I'm using ge0/2 - it plugs into a single Firewall device. (not a Cisco device).
Everything uses OSPF.
I am soon to be clustering my Firewall and therefore require 2 links into the 2921.
What is the easiest way to achieve this? I was thinking possibly about buying a ehwic card with 2 ethernet ports? How would i configure it all?
I look forward to hearing from you.
01-05-2014 03:49 AM
What is your WAN bandwidth?
01-05-2014 10:49 AM
100MB. Moving to 1GB in 2015.
01-05-2014 12:47 PM
If this is the case, then stop what you are doing. 2921 router is not designed to push 100 Mbps.
To be able to push 1 Gbps you should be looking at an ASR 1002 with RP2 and ESP 5 as a minimum. Otherwise, you are just wasting money on your WAN when your router is unable to push that much amount of bandwidth.
01-06-2014 02:23 AM
Thanks. Do you have some supporting documentation you could link me to? I'd be keen to reference it.
If we forget about that for a moment (as the speeds are currently OK and 2015 is a way off when I can review it) can anyone offer help with the original question?
Thank you.
01-07-2014 06:43 AM
Anyone able to offer any help?
Thank you.
01-07-2014 07:45 AM
It is not clear to me exactly what the requirements will be when you cluster your non Cisco firewalls and connect them to your router. Would I be correct in assuming that the requirements include: two physical interfaces on the router both in the same subnet and with a single IP address on the router? Perhaps the easiest way to achieve this would be to put a small switch module into the router, configure a vlan in the switch module assigning an IP address to the vlan interface, assign 2 of the switch ports to the vlan.
I am also not clear how the firewalls will connect to the router. Will each firewall have a direct physical connection to the router? Or is it possible that the firewalls will connect to a switch and the switch connects to the router? If the firewalls connect to a switch then perhaps you need only a single interface on the router?
Rick
01-07-2014 08:08 AM
Thank you.
The non-Cisco firewalls will each require 1 ethernet port from each firewall in the cluster to plug directly into the Cisco Router.
I could plug the firewalls into a switch - then plug that switch into the router using just one ethernet port.
However that's introducing a single point of failure (and nother device to maintain).
The ehwic card would hopefully do the same - I know that can still fail but we'd likely have a spare on standby.
So yes - switch module into router, configure vlan etc. I'm just not sure how I would do this.
It is currently configured like this:
interface GigabitEthernet0/1
mtu 1600
ip address 10.0.50.30 255.255.255.0
ip ospf message-digest-key 1 md5 7 xxxxxxxxxxx
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 10.0.60.70 255.255.255.0
ip flow ingress
ip ospf message-digest-key 1 md5 7 xxxxxxxxxxxx
duplex auto
speed auto
I'm just not sure what the process/commands would be to move from that to the whwic switch card etc.
Thanks.
01-07-2014 08:54 AM
The exact command syntax might vary a bit depending on the particular ehwic card that you use. But in general the process and the commands might look a bit like this:
! create a vlan on the switch module
vlan 101
name firewalls
! assign 2 switch ports to the vlan
interface fasteth0/0/0
switchport mode access
switchport access vlan 101
interface fasteth0/0/1
! remove the ip from the existing interface
no ip address
! create the vlan interface and assign IP address to it
interface vlan 101
You might need to check and/or experiment a bit to determine whether the ip flow ingress is supported on the ehwic or not.
Rick
