Additional BGP Process on Single Router
Hello Experts,
I have a problem with my lab. I need to be able to  run more than one BGP routing process on my lab router. I have over   connected BGP routers connected to my live production network and I  need to emulate the production network with GNS3. However, BGP rules  only allow a single BGP routing process on a single router.
Can someone please tell me how to overcome this limitation for my lab?
Cheers
Carlton
9 Replies 9
Peter Paluch
Hi Carlton,
Indeed, only a single BGP process can be running on a single router.
I am not sure if that would help but perhaps you could use the local-as feature to talk to specific neighbors as if you were in a different AS than the ASN you are currently running with. For example:
router bgp 1
  neighbor 1.2.3.4 remote-as 5
  neighbor 1.2.3.4 local-as 2
This would cause your BGP to talk to the peer 1.2.3.4 as if you were placed in AS number 2.
My two cents...
Best regards,
Peter
fb_webuser
Level 6
Level 6
Mr. Peter has given you the solution, just to add, make sure you have prefix-list present on your border router (router between your production and your lab network) to avoid funny routes propagation into your production network.
Musab
Posted by WebUser Musab Kiani from Cisco Support Community App
milan.kulik
Level 10
Level 10
I'm not sure if I understand your request 100%.
Do you need to achieve a second (separate) BGP table on your router?
Assigning a port to a VRF and
address-family ipv4 vrf ...
command in your config BGP section might help you possibly?
HTH,
Milan
Hello Milan,
I was thinking about using VRFs as well. However, it occured to me that a BGP running in VRF still inherits the ASN of the main BGP process so it does not really behave like two independent BGP instance. Therefore I suggested using the local-as instead.
Best regards,
Peter
Hi Peter,
well, what does the sentence "I need to be able to  run more than one BGP routing process on my lab router." mean in fact?
Is a separate BGP table requested (VRF) or is the clashing AS number (local-as) the root problem?
With local-as used, the BGP procsess also does not behave like two independent BGP instances, does it?
It's just masking the AS number, but creating a single BGP table.
BR,
Milan
Hello Milan,
Well, you're right as always No matter what solution we suggest, there is a drawback. local-as will get a shared BGP table, VRFs will get a shared ASN. It is simply not possible to run two totally separate instances of BGP on a single device to my best knowledge.
Best regards,
Peter
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I believe it's possible on those routers that support virtual routers (not just VRF) on a single device, but then it's logically two devices.
Joseph,
You're right, I did not think about this option. Still, this is supported only in IOS-XR, am I correct?
Best regards,
Peter
Disclaimer
Posting
Peter, I believe that's correct too.
