ADSL Interface dropping connection
brownie1985
I have an issue that I cannot seem to work out, wondering if anyone has experienced this before. We have an ADSL2+ line from a WIC in a 1841, everything has been fine for the last few years and then the last few months the connection going down. When checking the interfaces the ATM0/0/0 is up up and the same for the dialer interface we are using, they are both up/up, but this still needs a reload of the router to be functional again, shutting the interfaces does not bring the connection back up.
I am not an expert on ADSL lines, I have never really had a problem with anything previously. The router was running Netflow to a network monitor wondering if this or logging was causing an issue with entries in the buffer??
Here is an output of show dsl int, would anyone recommend changing the firmware, it has been fine all this time before though we are running IOS 12.4(24)T1 advseck9-m, as far as I can seen from our ISP the config for ADSL is all correct, completely stumped if anyone has any ideas that would be amazing!!
ATM0/0/0
Alcatel 20190 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM:     0x03                            0x2
Chip Vendor ID:  'STMI'                          'GSPN'
Chip Vendor Specific:  0x0000                    0x0010
Chip Vendor Country:   0x0F                      0xFF
Modem Vendor ID: 'CSCO'                          'GSPN'
Modem Vendor Specific: 0x0000                    0x1000
Modem Vendor Country:  0xB5                      0xFF
Serial Number Near:    FOC124200TYCISCO73993206
Serial Number Far:  Chip ID:     C196 (0)
DFE BOM:         DFE3.0 Annex A (1)
Capacity Used:   100%                            100%
Noise Margin:     9.0 dB                         10.0 dB
Output Power:    19.0 dBm                        12.5 dBm
Attenuation:     47.0 dB                         26.0 dB
FEC ES Errors:    0                               0
ES Errors:        0                               0
SES Errors:       0                               0
LOSES Errors:     0                               0
UES Errors:       0                               0
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0x68
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:      4132 (0 spurious)
PHY Access Err:  0
Activations:     1
LED Status:      OFF
LED On Time:     0
LED Off Time:    0
Init FW:         init_AMR-3.0.014_no_bist.bin
Operation FW:    AMR-3.0.014.bin
FW Source:       embedded
FW Version:      3.0.14
                 DS Channel1      DS Channel0   US Channel1       US Channel0
Speed (kbps):             0             7021             0               787
Cells:                    0          7086728             0          10613636
Reed-Solomon EC:          0                0             0                 0
CRC Errors:               0              874             0                 2
Header Errors:            0              586             0                 0
Total BER:                0E-0           5741E-9
Leakage Average BER:      0E-0           5602E-9
Interleave Delay:         0               56             0                51
Bitswap:               enabled            enabled
Bitswap success:          0                   0
Bitswap failure:          0                   0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 3 5 6 8 8 9 A A A B
010: A B B B A A A A 9 9 9 8 7 6 6 5
020: 0 5 7 9 A B B C C C C C C C C D
030: D D D D D D D D D D D D D D D D
040: D D D 2 C C C D C C C B B C C C
050: C C C C C C C C C C C C C C C B
060: B A A A A A B B B B B B B B B B
070: B B B B A A 9 9 A A A A A A A A
080: B B B A A B A A A 9 9 9 8 9 9 9
090: 9 9 9 9 9 A 9 9 8 8 8 8 8 8 8 8
0A0: 8 9 9 A 9 9 9 7 9 9 9 9 9 9 9 9
0B0: A 9 9 9 9 6 7 0 8 7 8 7 7 7 7 8
0C0: 8 7 8 7 5 7 8 7 7 7 7 7 7 6 6 7
0D0: 6 6 4 2 5 5 5 5 4 4 4 4 4 4 4 4
0E0: 4 2 2 4 4 4 3 4 4 2 2 2 2 2 2 0
0F0: 2 2 2 2 2 2 2 1 0 1 0 0 0 0 0 0
100: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
110: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
120: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
130: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
140: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
150: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
160: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
170: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
180: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
190: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1A0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1B0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
paolo bevilacqua
You should try updating firmware, however you also have high attenuation, check if telco can move you to a different pair.
Thanks for the advice I will give the firmware a try. I will mention the high attenuation see what they say, that is something I would not have picked up on.
I know this sounds stupid but does anyone know where the firmware is, so far I have had no luck finding it with our Cisco login, searching for our HWIC-1ADSL, I did read firmware can be stored in the IOS, is this correct I can't remember if this was just for an 800 series router? Looking up the Router under downloads certainly doesnt seem to display the correct WAN Interfaces for ADSL WIC.
Thanks again
Firmware is under 877 downloads, but a support contract is needed for downloads.
It was also on a public ftp before, now it seems that is gone also.
Many thanks will give this ago our contract will get us access to that firmware.
Thank you gives me some things to look into!
