ADSL Load Sharing
london.ism
Hey guys
I have 4 ADSL lines from the same ISP going into one Cisco 887VA router. Does anyone know how can I do load sharing between the 4 lines without getting the ISP involved?
At the moment I have route maps and policy based routing but that only works for fail over.
Thanks in advance
Elena
7 Replies 7
John Blakley
If you have equal cost routes, it will load share automatically. In other words, do you have 4 default gateways listed at the same time if you do a "show ip route"?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hi John
I have a gateway of last resort and then 4 S* (candidate default).
My set up is a bit more complicated then that. I have two LANs and one uses 2 of the ADSL lines (one as maine, the other as back up) and the other uses the remaining 2 in the same set up.
Elena
Can you post your config and "show ip route?"
Also, is the end goal for both lans to use all 4 links at all times?
HTH,
John
No, I would like one LAN to load share over two lines and the other LAN over the remaining two.
Gateway of last resort is x.x.x.x to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via x.x.x.x
        0.0.0.0/0 [1/0] via y.y.y.y
        0.0.0.0/0 [1/0] via z.z.z.z
        is directly connected, Dialer 0
Elena
You could configure properly NAT for each LAN. Route-map and ACL for different interface and do overload.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
Abzal
Best regards,
Abzal
Abzal
NAT is already configured in a very similar way to your example.
My question was about something different...
If I understood you correctly 4 links two of them as primary remain two as backup? If I'm correct
Perhaps this example might help you, combined with previous route-map NAT example.
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/813-cisco-router-ipsla-basic.html
Hope it will help
Best regards,
Abzal
