ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
adsl router 877 doubt
Hi.
I want to buy a cisco 3750 24p 10/100 to create 4 VLANs in a small enterprise. Then I want to connect each VLAN to a cisco 877 adsl router (4 ethernet ports), so it can do routing between VLANs and provide them internet access.
Am I doing all right? Has someone done something similar?
Thanks in advance.
PS: I'll skip doing routing in the 3750 because the enhanced image is very expensive.
1 REPLY 1
Highlighted
Hall of Fame Master
Re: adsl router 877 doubt
jose, the 3750 will route (at wire speed) just fine with the standard image. The enhanced image just adds more routing protocols and other things that doesn't seem you may need. Just configure one address per virtual interface on the 3750. Connect the 877 to one of these VLAN or create a new one. Make sure the 877 via static or dynamic routing knows about other subnets too.
