ADSL with cisco 871
lubosbella
our customer has a branch office that should be connected to central place via VPN site-to-site connection.
In branch is in use ADSL line via ethernet cable with name and password authentication again ISP network. For connection will be used a cisco 871 router in branch with two ethernet interfaces (LAN/WAN).
in central is ASA for VPN termination.
How to configure this router to work with ADSL circuit and what type of VPN to use? (maybe a PPPoE protocol...)
Can someone help how to configure this via CLI?
Many thanks.
Not necessary.
Please remember to rate useful posts with the scrollbox below.
7 Replies 7
paolo bevilacqua
Hi, take no offense but it seems to me you have no experience whatsoever in configuring routers and VPN solutions.
If you try that yourself no doubt you will get some result eventually, but it may cost you a lot of time and frustration.
My recommendation would be that you hire a reputable professional for the job.
Leo Laohoo
Paolo's right. Your current situation does not permit you to begin to learn while your client's network suffers. Find a spare unit to practice and learn.
Configuring Your Router for Ethernet and DSL Access
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/enetintr.html
Ok, no problem im not a cisco guru...so imagine that we are in testing environment....
Im going to do PPPoE against ISP. I used SDM (version 2.5) and it give me this set of command:
interface Vlan1
ip tcp adjust-mss 1412
exit
interface FastEthernet4
pppoe-client dial-pool-number 2
pppoe enable
exit
interface Dialer1
exit
default interface Dialer1
interface Dialer1
ip mtu 1452
no shutdown
ip address 62.168.11.52 255.255.255.192
dialer pool 2
dialer-group 1
encapsulation ppp
dialer idle-timeout 120
dialer fast-idle 20
ppp authentication chap pap callin
ppp pap sent-username jeff password 0 *****
ppp chap hostname jeff
ppp chap password 0 *****
exit
dialer-list 1 protocol ip permit
But my router stops on pppoe enable commnad with output: % Invalid input detected at '^' marker. So it is not know this command....i dont know why? - maybe needed only in older IOS...
If i try to set PPPoE step-by-step using this guide http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/enetintr.html then my router don`t know command protocol pppoe in vpdn enable--request dialin--(there is only protocol L2TP command)....
my IOS: Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
So im doing a mistake or i cant use this command in this IOS version?...
Problem is that i cant verify if my config is real working for now because i have not a dsl line with pppoe....so im looking for good preparation.
Thank.
The guides are sometime outdated and wrong.
If you use the SDM it will also make a lot of errors. For example the correct ip mtu on dialer1 should be 1492, not 1452. And 1452 as for adjust-mss. The rest seems fine.
Ok,
i corrected it to good values. So commands "pppoe enable" in fastethernet interface or "request dialin-->protocol pppoe" are probably not necessary with this vesion of IOS? (i cant type it and SDM write error)
Thanks.
Not necessary.
i set it up.
