Advertise Routes when destination unreachable
ahmad82pkn
Level 3
Level 3
Guys, need your help again as always.
What i want to achieve is track a destination, if that destination is unreacable then bring that static route into routing table.
i know Track can take our route from routing table if destination is unreachable, i want to bring route into table if destination is unreachable.
actually my Site A is advertising some routes in my internal MPLS cloud. if Site A WAN link goes down.i want to advertise same routes from Site B router. so i want to track Site A wan link or loopback from Site B router and advertise same routes if Loopback of Site A not reachable.
any suggestion?
Hi!
As per what you stated "  What i want to achieve is track a destination, if that destination is  unreacable then bring that static route into routing table"
I couldt find a related example on cisco website which fits, but i have a config for you which i wrote.
track 1 ip route 10.10.10.10/24 reachability
  event manager applet TRACK_IF_DOWN
    event track 1 state down
    action 1.0 cli command "enable"
    action 2.0 cli command "conf t"
    action 3.0 cli command "ip route 192.168.1.0 255.255.255.0 192.168.2.1"
    exit
  event manager applet TRACK_IF_UP
  event track 1 state up
    action 3.0 cli command "no ip route 192.168.1.0 255.255.255.0 192.168.2.1"
  exit
1] You can change the commands as per your need like for vrf "ip route vrf " and so on.
    Here is the link for Emebeded Event Manager
    http://www.cisco.com/en/US/docs/ios-xml/ios/eem/configuration/12-4t/eem-12-4t-book.html
2] You can use IP SLA with TRACK for tracking the destination as well.
Let me know if this helped. Thanks.
10 Replies 10
rais
Level 7
Level 7
Does it mean that constantly advertising routes from site B with inferior metrics [when compared to those of site A] won't work for you?
Thanks.
in my design not an option, i am running OSPF with carrier PE router, and they are doing BGP internal in their MPLS core. and all my attributes are lost in their cloud.
Try this out.
There is also a conditional default-route advertisement supported on Cisco ospf that you might be able to use.
HTH.
thank you, i will try this and see if it serves the purpose. thank you Rais.
Nandan Mathure
@ahmad82pkn
You can create a tracked object. Then create a event manager applet for "event track , state = down" and insert required "action cli " for advertising routes. & another applet to reverse the action when state = up.
That should work.
Nandan Mathure
can you give me some document URL for this?
Hi!
    exit
  exit
that is something really cool never came to know such flexibility exists .
Looks like my life is going to be lot easier.
thank you very much Nandan
If you can not modify the attritbutes to the MPLS network and you run ospf  between PE-CE I would recommend an other solution.
From the site A which is the primary site you could advertise all your subnets to the MPLS.
From the site B which is the backup site to advertise an ospf summary address  of these subnets.
So, the MPLS network, when both A and B are up selects the most specific subnets of Routers A to route the traffic. If Router A fails the traffic is routed via the summary address of Router B.
Hope that helps,
Vasilis
hi Vasileios, Thats what i am doing right now i thought to find another way.
