Advertise sub-interfaces via EIGRP?
jorge75medina
Im trying to advertise two sub-interfaces ip networks via eigrp. Is this possible?
5 Replies 5
Hello
Yes it possible, using the network command under the eigrp stanza should allow them to be advertised, that is unless you have filtering applied.
Kind Regards
Paul
I have tried that and I am having trouble still. It is a very simple topology on GNS3 and Packet tracer with two routers only, directly connected on a 10.0.0.0/30 interfaces, and two sub-interfaces with a 15.0.0.0/24 ip's. I have tried the "redistribute connected"  and "no auto-summary" options via EIGRP with no success. I tried it with loopback interfaces and it works just fine. EIGRP network statements are as follows: Router EIGRP 100>network 10.0.0.0 and network 15.0.0.0.
Should work fine.
Post a "sh ip int br" and a "sh ip ro" from your routers.
Jon
By the way the two sub-interfaces are on a different physical interface. For example, Gi0/0 ip address is 10.0.0.1/30 on R1 and the subinteraces is: Gi0/1 no shut, the Gi0/1.200, encapsulation dot1q, ip address 15.0.0.1/24. VLAN 200 is for the MGMT Network.
Cristian Matei
   As long as you match the corresponding IP subnet with your "network" statement, yes.
Cristian Matei.
