advertise the routes learned by eigrp into bgp AS
orsonjoon
I'm trying to build something in the lab where I want to use only one eigrp AS for two different locations where each others routes are learned over bgp (see picture)
I do a redistribute from and to eigrp and bgp, but not all the routes learned by the bgp router for example R3 are again advertised to other bgp neighbours.
R3#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     100.0.0.0/30 is subnetted, 1 subnets
C       100.100.100.0 is directly connected, FastEthernet0/0
     172.16.0.0/24 is subnetted, 1 subnets
D       172.16.0.0 [90/284160] via 10.10.10.1, 01:43:42, FastEthernet1/0
     10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C       10.10.10.0/24 is directly connected, FastEthernet1/0
B       10.0.0.0/30 [20/0] via 10.0.0.6, 00:37:04
C       10.0.0.4/30 is directly connected, FastEthernet0/1
B    192.168.0.0/24 [20/0] via 100.100.100.2, 01:19:50
R6#sh ip route
C       172.16.0.0 is directly connected, FastEthernet0/1
     10.0.0.0/24 is subnetted, 1 subnets
C       10.10.10.0 is directly connected, FastEthernet0/0
R2#sh ip route
     160.0.0.0/24 is subnetted, 1 subnets
D       160.0.0.0 [90/284160] via 192.168.0.1, 02:49:25, FastEthernet1/0
B       10.10.10.0/24 [20/0] via 100.100.100.1, 02:25:39
C       10.0.0.0/30 is directly connected, FastEthernet0/1
B       10.0.0.4/30 [20/0] via 10.0.0.2, 02:33:00
C    192.168.0.0/24 is directly connected, FastEthernet1/0
Is this just not possible or is this as designed or limitation? Please help....
Hello Orson,
on R3
router eigrp 65500
default-metric 10000 1500 255 1 1500
you need a seed metric when redistributing a routing protocol into EIGRP
see
http://www.cisco.com/en/US/docs/ios/iproute_eigrp/command/reference/ire_a1.html#wp1038657
and EIGRP troubleshooting flow chart
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094613.shtml#rdc
Hope to help
Giuseppe
6 Replies 6
Jon Marshall
Can you post
"sh ip bgp" from R1 and R2.
In answer to your question, yes it is possible.
Jon
Thanks for the quick answer, this is the sh ip bgp output:
R1#sh ip bgp
BGP table version is 7, local router ID is 10.0.0.6
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*  10.0.0.0/30      10.0.0.1                 0             0 65000 i
*>                  0.0.0.0                  0         32768 i
*> 10.0.0.4/30      0.0.0.0                  0         32768 i
*                   10.0.0.5                 0             0 65001 i
*  10.10.10.0/24    10.0.0.1                               0 65000 65001 i
*>                  10.0.0.5                 0             0 65001 i
*  100.100.100.0/30 10.0.0.5                 0             0 65001 i
*>                  10.0.0.1                 0             0 65000 i
*  192.168.0.0      10.0.0.5                               0 65001 65000 i
R1#
R2#sh ip bgp
BGP table version is 11, local router ID is 192.168.0.2
*  10.0.0.0/30      100.100.100.1                          0 65001 65002 i
*                   10.0.0.2                 0             0 65002 i
*  10.0.0.4/30      100.100.100.1            0             0 65001 i
*>                  10.0.0.2                 0             0 65002 i
*> 10.10.10.0/24    100.100.100.1            0             0 65001 i
*                   10.0.0.2                               0 65002 65001 i
*  100.100.100.0/30 100.100.100.1            0             0 65001 i
*> 192.168.0.0      0.0.0.0                  0         32768 i
R2#
Okay, i was looking at the network 172.16.0.0/24 which R3 knows about through EIGRP but R1 and R2 don't. But looking at R3 config you are not redistributing EIGRP into BGP so BGP wouldn't advertise it to R1.
Did you want to advertise EIGRP into BGP ?
Jon
Yes, I would like to advertise eigrp in bgp and also bgp into eigrp.
I changed the config of R3:
router eigrp 65500
redistribute bgp 65001
network 10.10.10.0 0.0.0.255
no auto-summary
router bgp 65001
no synchronization
bgp log-neighbor-changes
bgp redistribute-internal
network 10.0.0.4 mask 255.255.255.252
network 10.10.10.0 mask 255.255.255.0
network 100.100.100.0 mask 255.255.255.252
redistribute eigrp 65500
neighbor 10.0.0.6 remote-as 65002
neighbor 100.100.100.2 remote-as 65000
neighbor 100.100.100.2 soft-reconfiguration inbound
no auto-summary
It seems that the routes from eigrp are now correctly advertised into bgp:
R3#sh ip bgp neighbors 100.100.100.2 advertised-routes
BGP table version is 20, local router ID is 100.100.100.1
*> 10.0.0.0/30      10.0.0.6                 0             0 65002 i
*> 10.10.10.0/24    0.0.0.0                  0         32768 i
*> 100.100.100.0/30 0.0.0.0                  0         32768 i
*> 160.0.0.0/24     100.100.100.2       284160             0 65000 ?
*> 172.16.0.0/24    10.10.10.1          284160         32768 ?
*> 192.168.0.0      100.100.100.2            0             0 65000 i
Total number of prefixes 7
R3#sh ip route
D       172.16.0.0 [90/284160] via 10.10.10.1, 04:13:55, FastEthernet1/0
B       160.0.0.0 [20/284160] via 100.100.100.2, 00:15:53
B       10.0.0.0/30 [20/0] via 10.0.0.6, 03:07:16
B    192.168.0.0/24 [20/0] via 100.100.100.2, 03:50:02
But when I look in R6:
R6#sh ip route
router eigrp 65500
redistribute connected
network 172.16.0.0 0.0.0.255
no auto-summary
I can not see the 160.0.0.0 network for example, not all the routes know to BGP are redistibuted into eigrp. I think thats the problem, but don't no how to solve this. Looks like a eigrp issue, any ideas please help...
Hello Orson,
on R3
router eigrp 65500
see
Hope to help
Giuseppe
Yesssss, that did it many many thanks...., this one i'll never forget again
