Showing results forĀ
Search instead forĀ
Did you mean:Ā
Alexa
LUKASZ KITA
This is my topology:
modem----->ASA5505 192.168.1..---->Router1841 10.0.0..---->switch2960----linksys wifi router 10.28.181...
1841 is just for license purpose since 5505 has only 10 users.
Linksys is also on different subnet.
Question is:
Does Amazon Alexa need any special permissions to run thru ASA?
Every time I connect Alexa to wifi, internet goes down.
After unplugging Alexa from power, everything is back to normal.
Is there something with security, multicast, or something?
Thank you
Luke
Amazon Alexa/Echo nees the TCP/UDP ports below:
TCP: 67, 68, 80, 443, 8080, 40317
UDP: 53, 67, 68, 123, 1900, 5000, 5353, 33434, 40317, 49317, 50000
Can you even register your Alexa device (as described in the link below) ?
https://aws.amazon.com/blogs/business-productivity/setup-shared-devices-managed-by-alexa-for-business-on-wpa2-enterprise-wi-fi/
Thank you for the response.
This is just for testing purposes.
I will try to open those ports and see how it goes.
Thank you
