R4#show ip int br Interface IP-Address OK? Method Status Protocol FastEthernet0/0 172.16.9.2 YES manual up up Serial1/0 10.1.1.14 YES manual up up Serial1/1 unassigned YES unset administratively down down Serial1/2 unassigned YES unset administratively down down Serial1/3 unassigned YES unset administratively down down Loopback0 10.10.10.4 YES manual up up R4#show run Building configuration... Current configuration : 973 bytes ! version 12.2 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname R4 ! ! ip subnet-zero ! ! no ip domain-lookup ip domain-name lab.local ! call rsvp-sync ! ! ! ! ! ! ! ! interface Loopback0 ip address 10.10.10.4 255.255.255.255 ip router isis ! interface FastEthernet0/0 ip address 172.16.9.2 255.255.255.252 duplex auto speed auto ! interface Serial1/0 ip address 10.1.1.14 255.255.255.252 ip router isis tag-switching ip serial restart-delay 0 ! interface Serial1/1 no ip address shutdown serial restart-delay 0 ! interface Serial1/2 no ip address shutdown serial restart-delay 0 ! interface Serial1/3 no ip address shutdown serial restart-delay 0 ! router isis ! ip classless no ip http server ! ! ! dial-peer cor custom ! ! ! ! line con 0 exec-timeout 0 0 privilege level 15 logging synchronous line aux 0 exec-timeout 0 0 privilege level 15 logging synchronous line vty 0 4 login ! end R4#ping 172.16.9.1 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 172.16.9.1, timeout is 2 seconds: ..... Success rate is 0 percent (0/5) R4#ping 172.16.9.1 source 172.16.9.2 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 172.16.9.1, timeout is 2 seconds: Packet sent with a source address of 172.16.9.2 ..... Success rate is 0 percent (0/5) R4#show ip route Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2 ia - IS-IS inter area, * - candidate default, U - per-user static route o - ODR, P - periodic downloaded static route Gateway of last resort is not set 172.16.0.0/30 is subnetted, 1 subnets C 172.16.9.0 is directly connected, FastEthernet0/0 10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks C 10.1.1.12/30 is directly connected, Serial1/0 C 10.10.10.4/32 is directly connected, Loopback0 R4# | R9#show ip int br Interface IP-Address OK? Method Status Protocol FastEthernet0/0 172.16.9.1 YES manual up up FastEthernet0/1 unassigned YES unset administratively down down FastEthernet1/0 unassigned YES unset administratively down down R9#show run Building configuration...
Current configuration : 1020 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname R9 ! boot-start-marker boot-end-marker ! ! no aaa new-model memory-size iomem 15 no network-clock-participate slot 1 no network-clock-participate wic 0 ip cef ! ! ! ! no ip domain lookup ip domain name lab.local ip auth-proxy max-nodata-conns 3 ip admission max-nodata-conns 3 ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! interface FastEthernet0/0 ip address 172.16.9.1 255.255.255.252 duplex auto speed auto ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface FastEthernet1/0 no ip address shutdown duplex auto speed auto ! ip default-gateway 172.16.9.2 ip forward-protocol nd ! ! no ip http server no ip http secure-server ! ! ! ! control-plane ! ! ! ! ! ! ! ! ! ! line con 0 exec-timeout 0 0 privilege level 15 logging synchronous line aux 0 exec-timeout 0 0 privilege level 15 logging synchronous line vty 0 4 login ! ! end R9#ping 172.16.9.2 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 172.16.9.2, timeout is 2 seconds: ..... Success rate is 0 percent (0/5) R9#ping 172.16.9.2 sour R9#ping 172.16.9.2 source ? A.B.C.D Source address Async Async interface BVI Bridge-Group Virtual Interface CDMA-Ix CDMA Ix interface CTunnel CTunnel interface Dialer Dialer interface FastEthernet FastEthernet IEEE 802.3 Lex Lex interface Loopback Loopback interface MFR Multilink Frame Relay bundle interface Multilink Multilink-group interface Null Null interface Port-channel Ethernet Channel of interfaces Tunnel Tunnel interface Vif PGM Multicast Host interface Virtual-PPP Virtual PPP interface Virtual-Template Virtual Template interface Virtual-TokenRing Virtual TokenRing R9#ping 172.16.9.2 source 172.16.9.1 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 172.16.9.2, timeout is 2 seconds: Packet sent with a source address of 172.16.9.1 ..... Success rate is 0 percent (0/5) R9#show ip route Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2 i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2 ia - IS-IS inter area, * - candidate default, U - per-user static route o - ODR, P - periodic downloaded static route Gateway of last resort is not set 172.16.0.0/30 is subnetted, 1 subnets C 172.16.9.0 is directly connected, FastEthernet0/0 R9# |
