AnyConnect
Bob Greer
Level 4
Level 4
Hi there,
Thanks for reading.
I have users who are complaining about connection speeds using Anyconnect.  Speedtest without AC is 90-100Mbps as expected.  When they test while VPN connected, they get 1.9Mbps.
The AC Dart log AC Event view shows this connection speed:
Function: CVAMgr::setVALinkSpeed
File: VAMgr.cpp
Line: 855
Set VA link speed to: 241.78 Mbps
Is this event meaningful?
Thanks!
what are the AC clients connecting to, ASA or IOS router ? Are they using SSL or IPSec ?
And which AC client version are you using ?
Oftentimes MTU is the culprit, try different sizes (e.g. 1400)...
