07-28-2010 11:06 AM - last edited on 03-25-2019 03:29 PM by ciscomoderator
HARDWARE/ISSUE: AIRONET AP1240 which has a 2.4 GHz/ 5 GHz radios and is configured to be used as a access point for radio0 and non-root bridge for radio1 using Right instead of Diversity as its primary connections for the radios, but it would not allow our PDA sytems to connect to the internet.
Troubleshooting: I've checked the IOS, configuration, and its security configurations and none of these configurations have changed from when dot11 radio1 was still working. I checked the radio channel and the AP is set to a specific radio channel that would not interfere with the rest of the AP's within its group. I checked all physical hardware(cables and antennas) attached to the AP and nothing seems to have changed. After going through these steps, I replugged it and I was still unable to connect to the internet.
What could be the problem when I receive this message in the event log? Dot11 radio1 cannot associate; no response.
Solved! Go to Solution.
07-28-2010 04:04 PM
Can you post the "sh ip interface brief"?
07-28-2010 04:04 PM
07-29-2010 05:30 AM
IP interface:
BVI1 10.120.220.74 YES NVRAM up up
Dot11Radio0 unassigned YES NVRAM up up
Dot11Radio1 unassigned YES NVRAM reset down
FastEthernet0 unassigned YES NVRAM up down
07-29-2010 04:11 PM
Try reloading the AP and do a "sh log". This will tell you why Radio1 is on "reset".07-30-2010 07:20 AM
I don't understand what the problem could be. I see that when Interface BVI1 and its line protocol changes its state to up, Radio1 cannot associate.
I'm not sure what I need to do; should I disable the Ethernet in order for Radio1 to change its state to up?
Here's the Log:
Log Buffer (4096 bytes):
*Mar 1 00:00:05.109: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self t
est passed
*Mar 1 00:00:05.452: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar 1 00:00:06.388: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 0
*Mar 1 00:00:06.739: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Mar 1 00:00:07.752: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 1
*Mar 1 00:00:09.871: %SYS-6-LOGGERSTART: Logger process started
*Mar 1 00:00:09.873: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Mar 1 00:00:10.988: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to down
*Mar 1 00:00:11.387: %SYS-5-CONFIG_I: Configured from
*Mar 1 00:00:11.388: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1240 Software (C1240-K9W7-M), Version 12.3(8)JEA3, RELEASE
SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 21-Nov-07 13:59 by ccai
*Mar 1 00:00:11.388: %SNMP-5-COLDSTART: SNMP agent on host VPC_AP_YARD_4 is und
ergoing a cold start
*Mar 1 00:00:11.403: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power s
ource
*Mar 1 00:00:11.472: %LINK-3-UPDOWN: Interface Dot11Radio0, changed stInterface Dot11Radio1, cannot associa
te: No Response
ate to up
*Mar 1 00:00:12.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
1, changed state to down
0, changed state to up
*Mar 1 00:00:13.472: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:00:18.789: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to up
*Mar 1 00:00:20.789: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:00:21.789: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to up
*Mar 1 00:00:22.433: %DOT11-4-CANT_ASSOC: *Mar 1 00:01:37.404: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
08-01-2010 03:55 PM
Can you post the config of your AP?
08-02-2010 07:42 AM
Current configuration : 2313 bytes
version 12.3
no service pad
service password-encryption
hostname VPC_AP_YARD_4
enable secret 5 $1$p6f1$cLG4D2c1WJFZXFM47VCbo/
ip subnet-zero
no aaa new-model
dot11 ssid VPC-LOT-01
authentication open
authentication key-management wpa
wpa-psk ascii 7 11261A0B421A5A290B003D747F3C17230A0520553257706846673B571C300
E0965547B0351040D12080E4D293D320203251009735B63383D5C43175A235D2932
dot11 ssid VPC_PDA
authentication open
wpa-psk ascii 7 06101F22455A4828242D
power inline negotiation prestandard source
username mlydick privilege 15 password 7 15561C0514252F767B671607
username glovisadmin privilege 15 password 7 01140A0B4D02152F7115
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid VPC_PDA
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
channel 2412
fragment-threshold 1024
station-role root
antenna receive right
antenna transmit right
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid VPC-LOT-01
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role non-root
payload-encapsulation dot1h
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 10.120.220.74 255.255.255.0
no ip route-cache
ip http server
ip http authentication local
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community F50BC-glovis! RO
snmp-server location
snmp-server contact
snmp-server chassis-id AIR-AP1242AG-A-K9
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
08-02-2010 02:58 PM
Why do you have "station-role non-root" and "payload-encapsulation dot1h" in the config for Dot11Radio1? If Radio1 is to be used as an access point, this should be "station root".
08-03-2010 04:41 AM
Radio0 station role is an access point and Radio1 station role is a non-root bridge. That's why Radio1 configuration is 'station role non-root', but as for the config 'payload encapsulation dot1h', should this config be 'payload encapsulation dot11' ?
08-03-2010 04:45 AM
Also, should the config line 'payload encapsulation dot1h' be removed since it does not appear in the radio0 configuration?? What is the significance of this line in radio1?
08-03-2010 03:40 PM
Now I understand why it's on "reset". This is because Radio1 can't "see" the other Radio root-bridge. Maybe there's not enough signal (because you are using 802.11b). Switch the configuration around, meaning Radio0 is the non-root-bridge and Radio1 is the access-point. Make sure you switch the remote side too.08-03-2010 07:19 PM
I don't understand why I should switch both radio configurations? I monitor several AP's that have the same config as the one I'm having issues with. These AP's radio status are up and they provide adequate wireless signals within their designated area. I've tried to copy the configuration from these AP's, just changing specific details related to this AP and I still hav e the same issue. I'm' not sure why switching radio0 and radio1 configs would fix the issue if similar AP's are working fine. FYI... radio1 has wirless standard 802.11A, not B, and radio0 has wireless standard 802.11G if this helps.
08-03-2010 07:30 PM
Radio1 is 802.11a and Radio0 is 802.11b. In the wireless LAN world, 802.11b or "b" is well known for it's range and penetrating power in the expense of speed. 802.11a or "a" is the direct opposite: Short range, low penetrating power but high speed.
If you don't want to switch the configs, then try moving the AP closer.
