AS Numbers ???????
afzaalq007
hi,,
I want to know about the Autonomous system Types (AS) ???
why we catageries AS .. what are the reasons. ???
can we use AS number with IGPS ???
New method of AS representation ????
please forward me any cisco link
thanks and regards
Afzaal Qadir
7 Replies 7
globalnettech
Level 5
Level 5
Hello Afzaal,
what exactly do you mean with IGPS ? I only know this in connection with RFID tracking systems...that is probably not what you are referring to ?
GNT
icabrera
Level 4
Level 4
A good cisco link about AS:
http://www.cisco.com/web/about/ac123/ac147/archived_issues/ipj_9-1/autonomous_system_numbers.html
Hope this information is helpful, if so pls rate the post
hi
Thanks for the reply
Wht is the basic differne between IBGP and EBGP...
Or is it true
that always IBGP runs btween EBGP and IGPs
{EBGP------>IBGP<---------IGP}
and one thing more i want to ask that is there a possibility that we can use static routes between two public Autonomous system .
The difference between eBGP and IBGP is that you would run iBGP within an AS in order to carry BGP updates from one eBGP speaking router to another. IGPs are not suitable for this purpose since they can neither scale to a large number of routes nor are able to carry all the BGP attributes.
Paresh
Hi, there is a very goog document at cco it can answers most of your question. Take a look to it and you'll learn a lot about BGP.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml
Hii
What will happen when in advertize same prefix from two differnt Autonomous system ????
will it advertize ????
after advertizment it will route traffic or not ???
Two different foreign ASs can advertise the same prefix, but the receiver will filter the best based on the bgp selection criteria (eg shorter AS path).Only one best route will be installed in the routing table.
