08-12-2009 07:40 AM - edited 03-04-2019 05:43 AM
Hi experts,
I am practising AS-PATH regular expression.
To allow any at the end of as-path access-list i found that document saying
But I tried with _ (meaning any starting, ending, paranthesis ) alone. it is
aslo working fine. Shall i use this instead of .* in lan. Is there any
significant difference is there.
example:
ip as-path access-list 1 deny _300$
ip as-path access-list 1 permit _
Thanks in advance
sairam
Solved! Go to Solution.
08-12-2009 11:50 AM
Hi Sairam,
I think you can use the underscore as the "permit any" without problems. For people more used to classical regular expressions, the ".*" syntax is more readable but the underscore works here as well and I believe that there are almost no efficiency differences between evaluating these two expressions.
Best regards,
Peter
08-12-2009 11:50 AM
Hi Sairam,
Best regards,
Peter
