03-26-2015 07:23 AM - edited 03-05-2019 01:06 AM
Good morning everyone. I am in need of some help. I am a newbie when it comes to configuring the ASA. Here is my problem. I have the asa configure and it is allowing me to get out to the internet. I have several VLANs on my network and from inside I can ping everything. I have created the VPN and I am able to connect to it and get in IP assigned from the pool of address. If I have multiple connections I can ping the other PCs. Right now I am able to ping the outside and inside interfaces of the ASA but no where else. I have split tunneling enabled. Here is a copy of my config.
Dave
Result of the command: "sh run"
: Saved
: Serial Number: *****
: Hardware: ASA5505, 512 MB RAM, CPU Geode 500 MHz
ASA Version 9.1(5)21
hostname Main-ASA
domain-name *****
enable password ***** encrypted
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
names
ip local pool AnyC-CPN-Client-Pool 192.168.59.0-192.168.59.250 mask 255.255.255.0
interface Ethernet0/0
switchport access vlan 12
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan2
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.252
interface Vlan12
nameif Outside
security-level 0
ip address dhcp setroute
banner login *************************************
banner login Unuathorized access is prohibited !!
ftp mode passive
clock timezone MST -7
clock summer-time MDT recurring
dns domain-lookup inside
dns domain-lookup Outside
dns server-group DefaultDNS
domain-name *****
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network VLAN54
subnet 192.168.54.0 255.255.255.0
description VLAN 54
object network Management
subnet 192.168.80.0 255.255.255.0
description Management
object network VLAN51
subnet 192.168.51.0 255.255.255.0
description VLAN 51
object network VLAN52
subnet 192.168.52.0 255.255.255.0
description VLAN 52
object network VLAN53
subnet 192.168.53.0 255.255.255.0
description VLAN 53
object network VLAN55
subnet 192.168.55.0 255.255.255.0
description VLAN 55
object network VLAN56
subnet 192.168.56.0 255.255.255.0
description VLAN 56
object service 443
service tcp destination eq https
object service 80
service tcp destination eq www
object service 8245
service tcp destination eq 8245
object service 25295
service udp destination eq 25295
description Blocking 25295
object network VPN-Connections
subnet 192.168.59.0 255.255.255.0
description VPN Connections
object-group service No-IP
description no-ip.com DDNS Update
service-object object 80
service-object object 8245
service-object object 443
access-list inside_access_in remark No-ip DDNS Update
access-list inside_access_in extended permit object-group No-IP object VLAN51 any
access-list inside_access_in extended permit ip any any
access-list VPN standard permit 192.168.0.0 255.255.0.0
access-list Outside_access_in remark Blocking 25295 to HTPC
access-list Outside_access_in extended deny object 25295 any object VLAN54
pager lines 24
logging enable
logging asdm warnings
mtu inside 1500
mtu Outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,Outside) source dynamic any interface
access-group inside_access_in in interface inside
access-group Outside_access_in in interface Outside
router eigrp 1
no auto-summary
network 192.168.0.0 255.255.255.252
network 192.168.59.0 255.255.255.0
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server LDAP protocol ldap
aaa-server LDAP (inside) host 192.168.51.1
server-port 636
ldap-base-dn cn=users,dc=spicerslocal
ldap-scope subtree
ldap-naming-attribute cn
ldap-login-password *****
ldap-login-dn cn=users,dc=*****
sasl-mechanism digest-md5
ldap-over-ssl enable
server-type microsoft
user-identity default-domain LOCAL
http server enable
http 192.168.0.0 255.255.0.0 inside
http 0.0.0.0 0.0.0.0 Outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES
protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map Outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map Outside_map interface Outside
crypto map inside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map interface inside
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
subject-name CN=Main-ASA
crl configure
crypto ca trustpool policy
crypto ca certificate chain ASDM_TrustPoint0
certificate
quit
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable Outside
crypto ikev2 remote-access trustpoint ASDM_TrustPoint0
telnet timeout 5
ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access inside
vpn-addr-assign local reuse-delay 5
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_TrustPoint0 Outside
ssl trust-point ASDM_TrustPoint0 inside
webvpn
enable Outside
anyconnect image disk0:/anyconnect-win-3.1.06079-k9.pkg 1
anyconnect image disk0:/anyconnect-linux-2.5.2014-k9.pkg 2
anyconnect image disk0:/anyconnect-macosx-i386-2.5.2014-k9.pkg 3
anyconnect profiles AnyC-SSL-VPN_client_profile disk0:/AnyC-SSL-VPN_client_profile.xml
anyconnect enable
tunnel-group-list enable
group-policy DfltGrpPolicy attributes
dns-server value 192.168.51.1 8.8.8.8
vpn-tunnel-protocol ikev1 ikev2 l2tp-ipsec ssl-client ssl-clientless
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPN
default-domain value *****
split-dns value 8.8.8.8
group-policy GroupPolicy_AnyC-SSL-VPN internal
group-policy GroupPolicy_AnyC-SSL-VPN attributes
wins-server none
dns-server value 8.8.8.8
vpn-tunnel-protocol ikev2 ssl-client
webvpn
anyconnect profiles value AnyC-SSL-VPN_client_profile type user
username Dave password ***** encrypted privilege 15
username Don password ***** encrypted privilege 15
tunnel-group AnyC-SSL-VPN type remote-access
tunnel-group AnyC-SSL-VPN general-attributes
address-pool AnyC-CPN-Client-Pool
tunnel-group AnyC-SSL-VPN webvpn-attributes
group-alias AnyC-SSL-VPN enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:af0fad1092e0314b0a80f20add03e3f7
: end
03-30-2015 12:20 PM
Hi Dave,
It seems to be an issue with the NAT, I saw your VPN configuration:
You will need to set up a NAT exemption as follow:
object-group network obj-192.168.59.0-Pool
network-object 192.168.59.0 255.255.255.0
object-group network obj-192.168.0.0
network-object 192.168.0.0 255.255.0.0
nat (inside,outside) 1 source static obj-192.168.0.0 obj-192.168.0.0 destination static obj-192.168.59.0-Pool obj-192.168.59.0-Pool no-proxy-arp route-lookup
Please proceed to rate and mark as correct this post, if it helps!
David Castro,
03-31-2015 11:41 AM
Ok Thanks for you reply David. I made the changes you suggested and which I also posted below for reference. With this change I was able to access the shares through the VPN but now it seems to have broke my Split tunneling. Any ideas how how to fix that part?
Dave
03-31-2015 11:53 AM
Hi Dave,
It is actually pretty strange that It broke your access to the Share folders. Could you provide the following:
- The IP range of the Share folders?
- Are they coming from the inside network or other interface?
- Is this happening with all the users?
- If you remove the NAT exemption, does it start working?
David Castro,
