gaborgregor67
Beginner
ASA EasyVPN connection on two WAN same time setting
Hello everyone,
I'm looking for help with the following problem.
Given WAN1, WAN2, LAN1. I want to connect to both WAN sites at the same time with an Easy VPN client and use LAN side services.
My experience is that both VPN connections are established, but unfortunately I can only communicate in the tunnel on the line that is the default gateway in the router.
What should be set up so that clients on both WAN lines can use a VPN connection at the same time?
Thanks G
0 REPLIES 0
