ASA Issues
daniel_growth
Hi All,
I need my CORP lan to ping the server and pc's within their ranges. I am unable to get this to work despite looking at static routing and acl rules. I have attached the PKT file and all passwords are "cisco". If you are able to get it pinging please do return and explain how you got it to work so i can learn from it
I look forward to your replies and thank you in advance for support!
Switch 1:
version 12.2(37)SE1
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname CORP_SWT_1
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
ip dhcp excluded-address 137.223.25.0 137.223.25.10
ip dhcp pool CORP_RANGE
network 137.223.25.0 255.255.255.0
default-router 137.223.25.1
ip routing
no ip domain-lookup
spanning-tree mode pvst
interface Loopback1
ip address 216.27.61.137 255.255.255.248
interface FastEthernet0/1
shutdown
interface FastEthernet0/2
shutdown
interface FastEthernet0/3
shutdown
interface FastEthernet0/4
shutdown
interface FastEthernet0/5
shutdown
interface FastEthernet0/6
shutdown
interface FastEthernet0/7
shutdown
interface FastEthernet0/8
shutdown
interface FastEthernet0/9
shutdown
interface FastEthernet0/10
shutdown
interface FastEthernet0/11
shutdown
interface FastEthernet0/12
shutdown
interface FastEthernet0/13
shutdown
interface FastEthernet0/14
shutdown
interface FastEthernet0/15
shutdown
interface FastEthernet0/16
shutdown
interface FastEthernet0/17
shutdown
interface FastEthernet0/18
shutdown
interface FastEthernet0/19
shutdown
interface FastEthernet0/20
shutdown
interface FastEthernet0/21
shutdown
interface FastEthernet0/22
shutdown
interface FastEthernet0/23
shutdown
interface FastEthernet0/24
shutdown
interface GigabitEthernet0/1
switchport access vlan 137
switchport mode access
switchport nonegotiate
interface GigabitEthernet0/2
no switchport
ip address 137.223.27.1 255.255.255.252
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan137
mac-address 0060.5c6e.2601
ip address 137.223.25.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 137.223.27.2
ip flow-export version 9
no cdp run
line con 0
password 7 0822455D0A16
logging synchronous
login
line aux 0
logging synchronous
line vty 0 4
logging synchronous
login
line vty 5 15
logging synchronous
login
end
Firewall:
ASA Version 9.6(1)
hostname ciscoasa
names
interface GigabitEthernet1/1
nameif inside
security-level 100
ip address 172.16.27.2 255.255.255.252
interface GigabitEthernet1/2
nameif outside
security-level 0
ip address 137.223.27.2 255.255.255.252
interface GigabitEthernet1/3
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/4
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/5
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/6
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/7
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/8
no nameif
no security-level
no ip address
shutdown
interface Management1/1
management-only
no nameif
no security-level
no ip address
object network obj_any
subnet 0.0.0.0 0.0.0.0
route inside 172.16.24.0 255.255.255.192 172.16.27.1 1
route outside 0.0.0.0 0.0.0.0 137.223.27.1 1
access-list R&DZ1-CORP-AllowAll extended permit ip host 172.16.24.11 host 137.223.25.11
access-list outside_access_in extended permit icmp any any
access-list OUTSIDE_IN extended permit icmp any any echo-reply
access-list OUTSIDE_IN extended permit icmp any any unreachable
access-group OUTSIDE_IN in interface outside
access-group OUTSIDE_IN in interface inside
nat (any,outside) dynamic interface
class-map inspection_default
match default-inspection-traffic
policy-map glabal_policy
policy-map global_policy
telnet timeout 5
ssh timeout 5
Switch 2:
version 12.2(37)SE1
hostname R&D_LAN
ip routing
no ip domain-lookup
switchport trunk allowed vlan 51
switchport mode trunk
switchport trunk allowed vlan 52
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
no switchport
ip address 172.16.27.1 255.255.255.252
duplex auto
speed auto
switchport access vlan 72
interface Vlan1
no ip address
shutdown
interface Vlan51
mac-address 0002.17e1.ed01
ip address 172.16.24.1 255.255.255.192
interface Vlan52
mac-address 0002.17e1.ed02
ip address 172.16.24.65 255.255.255.192
interface Vlan72
mac-address 0002.17e1.ed03
ip address 172.16.25.1 255.255.255.248
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.27.2
no cdp run
banner motd ^C
Authorized users only, violaters will be subject to legal charges! ^C
line con 0
logging synchronous
login
line aux 0
logging synchronous
login
line vty 0 4
logging synchronous
login
line vty 5 15
logging synchronous
login
end
Kind Regards,
Daniel Growth
not really sure why your setup doesn't work, when I add the routes, I can ping everything. I have attached the revised, working file, and also the working ASA config.
ciscoasa#sh run
: Saved
ASA Version 9.6(1)
hostname ciscoasa
names
nameif inside
security-level 100
nameif outside
security-level 0
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
management-only
no nameif
no security-level
no ip address
shutdown
route inside 172.16.24.64 255.255.255.192 172.16.27.1 1
route inside 172.16.25.0 255.255.255.248 172.16.27.1 1
access-list OUT_IN extended permit ip any any
access-list IN_OUT extended permit ip any any
access-group IN_OUT in interface outside
access-group IN_OUT in interface inside
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
class inspection_default
inspect ftp
inspect tftp
service-policy global_policy global
telnet timeout 5
ssh timeout 5
ciscoasa#
8 Replies 8
on the ASA, you only have a 'route outside' towards the Vlan 71 network. You need to add a route outside to the other networks in Vlan 72 and 75 as well...
Yes I know. From clan 71 I cannot ping corp Lan back and forth. Until I manage to fix this issue I will not attempt to route the others as they will also be wrong based in my current config.
Kind Regards,
Daniel Growth
Icmp inspection to allow asa icmp pass through.
Hi, thanks for the reply. When i look for those ICMP commands I see that they are not supported within packet tracer. Could you give me an example within context of my network to try and paste within the ASA?
Kind Regards,
Daniel Growth
the access lists are the problem. I allowed everything in and out in the attached revised fiile, and the ping works. You need to look at the access lists.
That said, when you open the file, both ASA interfaces are in 'shutdown' mode by defauly.
Hey,
Thanks for getting back to me. I tried the ping and it didnt work the first few times but does now from zone 1 to the corp and corp to zone 1. I need to get the server and zone 2 also communicating with the corp lan and vise vera.
i added the above command and based off your route of zone 1 and it doesnt work? I really dont understand
Kind Regards,
Daniel Growth
ciscoasa#sh run
: Saved
ASA Version 9.6(1)
hostname ciscoasa
names
nameif inside
security-level 100
nameif outside
security-level 0
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
management-only
no nameif
no security-level
no ip address
shutdown
parameters
inspect ftp
inspect tftp
telnet timeout 5
ssh timeout 5
ciscoasa#
