ASA logging issue
mze
We are unable to get the logging information on this below mentioned devices.
3 Accepted Solutions
we understand that,  try below what is the outcome, does the syslog server reachable to ASA 10.1.1.1
no logging host Inside 10.1.1.1. 17/10516
BB
which syslog server are you using ? It might not understand facility 16 - 23. Try and remove
logging facility 22
from the configuration.
Hello
Suggest also to decrease your logging queue, so the asa wont discard so many if it cannot handle them due to such a large queue size.and also reset the logging port to udp 514, test again
llogging host inside x.x.x.x udp 514
logging queue 100
Kind Regards
Paul
12 Replies 12
johnd2310
Level 8
Level 8
What is your logging configuration?
John
**Please rate posts you find helpful**
balaji.bandi
where you not seeing logs ? or sending logs to syslog ?
check below document for reference ;
https://www.cisco.com/c/en/us/support/docs/security/pix-500-series-security-appliances/63884-config-asa-00.html
BB
mze
logging issue
logging issue
                                  - >... logging host Inside 10.1.1.1. 17/10516
 As far as I understand  it the arguments following IP address of the syslog server should denote Protocol/Port-number. Protocol refers to UDP or TCP.
 M.
Hey,
As per my understanding you're trying to send SYSLOGs to the external SYSLOG server. Questions that come to my mind:
1) Is there end-to-end connectivity between ASA(s) and SYSLOG server?
2) Can the traffic be policy-dropped (f.e. ACL, another firewall etc.) before reaching the server?
You can refer to this documentation file: https://www.cisco.com/c/en/us/support/docs/security/pix-500-series-security-appliances/63884-config-asa-00.html#anc6
thanks
BB
what you mean in red color your point of view ?
BB
logging facility 22
I think the suggestion about logging facility is a good one. I also wonder about the use of a non standard protocol port number for the syslog messages. Are you sure that the syslog server is looking for port 10516?
Rick
Hello
logging queue 100
Kind Regards
Paul
