05-09-2011 06:09 AM - edited 03-04-2019 12:19 PM
Hi all,
Plz help me. Have a problem in config of my ASA5505 --> I can't access Internet from my new created vlan number 4 (Vlan4):
here my config:
ASA Version 8.4(1)
hostname FWWIB1
enable password OEIOH8Zv/vNvif8C encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif WIB
security-level 100
ip address 192.168.222.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp
interface Vlan4
nameif ETC
security-level 60
ip address 192.168.16.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 4
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa841-k8.bin
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns domain-lookup WIB
dns domain-lookup ETC
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 192.168.1.1
name-server 195.186.1.162
name-server 62.2.17.61
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network NETWORK_OBJ_192.168.55.0_25
subnet 192.168.55.0 255.255.255.128
object network NETWORK_OBJ_192.168.222.0_24
subnet 192.168.222.0 255.255.255.0
object network Vigor
host 192.168.1.1
access-list WIBRAS4ALL_splitTunnelAcl standard permit 192.168.222.0 255.255.255.0
access-list WIB_access_in extended permit ip any any
access-list ETC_access_in extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu WIB 1500
mtu outside 1500
mtu ETC 1500
ip local pool WIBRASPool 192.168.55.55-192.168.55.65 mask 255.255.255.0
ip verify reverse-path interface outside
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp deny any outside
asdm image disk0:/asdm-641.bin
no asdm history enable
arp timeout 14400
nat (WIB,outside) source dynamic any interface
nat (WIB,outside) source static any any destination static NETWORK_OBJ_192.168.55.0_25 NETWORK_OBJ_192.168.55.0_25
nat (WIB,outside) source static NETWORK_OBJ_192.168.222.0_24 NETWORK_OBJ_192.168.222.0_24 destination static NETWORK_OBJ_192.168.55.0_25 NETWORK_OBJ_192.168.55.0_25
nat (ETC,outside) source static any any
nat (ETC,outside) source dynamic any interface
nat (any,outside) dynamic interface
access-group WIB_access_in in interface WIB
access-group ETC_access_in in interface ETC
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.222.0 255.255.255.0 WIB
http 192.168.16.0 255.255.255.0 ETC
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.222.120-192.168.222.254 WIB
dhcpd dns 192.168.1.1 8.8.8.8 interface WIB
dhcpd lease 864000 interface WIB
dhcpd enable WIB
dhcpd address 192.168.16.20-192.168.16.200 ETC
dhcpd dns 192.168.1.1 8.8.8.8 interface ETC
dhcpd lease 864000 interface ETC
dhcpd enable ETC
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port number-of-rate 3
threat-detection statistics protocol number-of-rate 3
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 162.23.41.34 source outside
ntp server 194.88.212.205 source outside prefer
webvpn
group-policy WIBRAS4ALL internal
group-policy WIBRAS4ALL attributes
vpn-tunnel-protocol ikev1 ssl-clientless
split-tunnel-policy tunnelspecified
split-tunnel-network-list value WIBRAS4ALL_splitTunnelAcl
username xxxxx password jezwB8dcsgMWFU1Q encrypted privilege 15
username xxxxx attributes
vpn-group-policy WIBRAS4ALL
username yyyyyy password 2s6hsBEa4EwJPz5A encrypted privilege 15
username yyyyyy attributes
username zzzzzz password pAYFNGNl7qIaXsZT encrypted privilege 15
username zzzzzz attributes
username fffffff password 7a9Uq15CRaie7CdZ encrypted privilege 15
username fffffff attributes
tunnel-group WIBRAS4ALL type remote-access
tunnel-group WIBRAS4ALL general-attributes
address-pool WIBRASPool
default-group-policy WIBRAS4ALL
tunnel-group WIBRAS4ALL ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:c7bd768aaa1575f1b035ac6b02855311
: end
thx 4 any suggestions.
Chris
Solved! Go to Solution.
05-09-2011 07:52 AM
Did you check "show xlate" for 192.16816.0/24 network? Do you want 192.168.16.0/24 network going to the internet natted by an outside interface?
Please try this if you want to do NAT on outside interface:
no nat (ETC,outside) source dynamic any interface
no nat (ETC,outside) source static any any
object network ETC-VLAN4
subnet 192.168.16.0 255.255.255.0
nat (ETC,outside) dynamic interface
HTH,
Toshi
05-09-2011 06:20 AM
ASA5505 requires Security Plus license to support DMZs, do you have it?
05-09-2011 06:22 AM
Hi Roman,
yes i have the sec plus license.
05-09-2011 07:52 AM
HTH,
Toshi
05-09-2011 08:20 AM
hi all,
Thx 4 helping me.
in meantime i deleted all the definitions about vlan4 and created it new from scratch....now it works, but don't ask me why.
maybe it has something to do with NAT definitions as Thosi said.
Thx a lot again to all !!!
Chris
