ASR 1000 module uptime
Anukalp S
Hi, could you confirm what do we say about the timer mentioned before uptime of module in show platform diag output on ASR 1000.
Want to understand about the timer (00:02:09) is it kind of keepalive
Slot: F0, ASR1000-ESP20
Running state : ok, active
Internal state : online
Internal operational state : ok
Physical insert detect time : 00:02:09 (1y3w ago)
Software declared up time : 00:02:55 (1y3w ago)
Hardware ready signal time : 00:02:10 (1y3w ago)
Packet ready signal time : 00:03:17 (1y3w ago)
marce1000
 - Looking at the value between brackets this counter may have wrapped.
 M.
Thanks, i am planning to replace ESP20 module with RMA,  router(ASR 1004) has only one RP , no redundant RP. Please suggest if router reload is required post replacing ESP20 module in F0 slot.
Hello @Anukalp S ,
there is no evidence the ESP20 module is faulty what @marce1000 was suggesting is a wrapping of the timer that means that the timer has reached the maximum value (think of it like a binary integer 32 bits using msecs for example ) and has started again this is the common meaning of wrapping in the round brackets we see an uptime of over one year.
There is any impact on user traffic ?
IF all you see is what you have reported in your first post it is too early to ask for an RMA
Hope to help
Giuseppe
