ASR 1001 x SFP-GE-T speed
rleao
Hi Everybody,
I´m making a proposal for a costumer where he needs connect one ASR 1001 with other ASR1001 via UTP cable.  The speed will be 100 Mbps at this moment.   Can I use the SFP-GE-T tranceiver for a 10/100/1000 Mbps connection ?
Thank you.
7 Replies 7
JohnTylerPearce
Level 7
Level 7
rleao,
This should be a problem.
I know the ASR1001 comes with a fixed 2.5 Gbps ESP.
Cisco ASR 1001 and ASR 1002-X Routers come with a nonmodular, fixed ESP with throughput of 2.5 Gbps (for ASR 1001)
So as long as you don't make out the ESP module, with other ports you should be fine.
Jonhy,
But hte ASR 1001 has 4 SFP built-in GE ports, is correct ?  Could these ports use SFP-GE-T with speed 10/100/1000 Mbps ?
The following are supported by the CIsco ASR 1000 sries.
SFP-GE-T
SFP-GE-S
SFP-GE-L
SFP-GE-Z
CWDM SFP
DWDM SFP
GLC-BX-D
GLC-BX-U
GLC-SX-MMD
GLC-LH-SMD
GLC-ZX-SMD
This link may help you out
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp131775
Thank you !
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I believe the copper SFP supports 10/100/1000.
Johny,
we have similar problem with speed rate on SFPes in built-in GE ports of ASR1001.  We also believe the copper SFP supports 10/100/1000 Mbps.
Could you please explain to me what is difference between Cisco SFP-GE-T and Cisco DS-SFP-GE-T?  I would like to ask you for explanation of this difference.
Both SFP modules are working in built-in GE ports of ASR1001, however, DS-SFP-GE-T accepts the speed command for setting 100Mbps speed rate but SFP-GE-T not.
