ASR 1004 - Portchannel - Service policy not supported
stanibarb
I cannot configure service policy on a Layer 3 portchannel on ASR 1004 with Cisco IOS XE 3.5.1, in which is supposed to be supported. This the information that i had:
access-list 1 permit ip any host xxxx time-range LAN-time
class-map match-any CLASS
match access-group 1
policy-map MAP
class CLASS
  shape average 71680000
interface Port-channel1
ip address xxxx
no ip redirects
no ip proxy-arp
ip flow ingress
standby 85 ip xxxx
standby 85 priority 150
standby 85 preempt
load-interval 30
no negotiation auto
(config)#interface Port-channel1
(config-if)#service-policy output MAP
service-policy output Inside-SHAPE-map not supported on this target
#sh ver
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-ADVIPSERVICESK9-M), Version 15.2(1)S1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 15-Feb-12 21:54 by mcpre
System image file is "bootflash:/asr1000rp2-advipservicesk9.03.05.01.S.152-1.S1.bin"
thank you very much for the assistance in advance!
BR,
Stanley
Hi stanley,
take a look at this:
https://supportforums.cisco.com/thread/2056332
Rate if it helps
Alessio
