ASR 1004 Upgrade
shaimaafahmy
Dear All,
in my work there is a warning keep showing on ASR 1004 router as below
%PLATFORM-4-ELEMENT_WARNING: R0/0: smand:  SIP/0: Committed Memory value 98% exceeds warning level 95%
 i googled that log and found that its a bug in calculation of memory and can be solved by upgrade IOS image to Cisco recommended version "as per Cisco website" which is 3.13.6aS
it is my first time to upgrade this IOS-XE routers, i used to update IOS router with below order of command
copy tftp flash
boot system flash
write
reload
while i check cisco website and found that i have to use about 19 step in upgrade using sub packages of the consolidated package
i have two question
first, is it really i have to use platform request commands and the 19 steps ? can't i simply use the common way of IOS upgrade as i mentioned above
second, i don't have enough memory space to hold both images as below, what should i do ?
Router#sh ver
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.0(1)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Jul-10 21:34 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 1 year, 38 weeks, 6 days, 23 hours, 18 minutes
Uptime for this control processor is 1 year, 38 weeks, 6 days, 23 hours, 21 minutes
System returned to ROM by reload at 14:12:56 UTC Fri Apr 15 2011
System restarted at 15:22:40 EST Mon Feb 23 2015
System image file is "bootflash:/asr1000rp1-adventerprisek9.03.01.00.S.150-1.S.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1004 (RP1) processor with 1717513K/6147K bytes of memory.
10 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
937983K bytes of eUSB flash at bootflash:.
39004543K bytes of SATA hard disk at harddisk:.
Router#sh bootflash:
-#- --length-- ---------date/time--------- path
1 4096 Nov 22 2016 14:39:31 +00:00 /bootflash/
2 16384 Apr 15 2011 15:17:05 +00:00 /bootflash/lost+found
3 63332664 Apr 15 2011 15:17:46 +00:00 /bootflash/asr1000rp1-sipspawmak9.03.01.00.S.150-1.S.pkg
4 276400440 Apr 15 2011 15:19:43 +00:00 /bootflash/asr1000rp1-adventerprisek9.03.01.00.S.150-1.S.bin
5 4096 Apr 15 2011 15:18:45 +00:00 /bootflash/.installer
6 4096 Apr 15 2011 15:49:28 +00:00 /bootflash/.prst_sync
7 66240816 Apr 15 2011 15:20:09 +00:00 /bootflash/asr1000rp1-espbase.03.01.00.S.150-1.S.pkg
8 8567 Apr 15 2011 15:53:04 +00:00 /bootflash/asr1000rp1-packages-adventerprisek9.03.01.00.S.150-1.S.conf
9 24424752 Apr 15 2011 15:20:11 +00:00 /bootflash/asr1000rp1-rpaccess.03.01.00.S.150-1.S.pkg
10 33993008 Apr 15 2011 15:20:14 +00:00 /bootflash/asr1000rp1-rpbase.03.01.00.S.150-1.S.pkg
11 23920944 Apr 15 2011 15:20:16 +00:00 /bootflash/asr1000rp1-rpcontrol.03.01.00.S.150-1.S.pkg
12 58855736 Apr 15 2011 15:20:22 +00:00 /bootflash/asr1000rp1-rpios-adventerprisek9.03.01.00.S.150-1.S.pkg
13 37636400 Apr 15 2011 15:20:26 +00:00 /bootflash/asr1000rp1-sipbase.03.01.00.S.150-1.S.pkg
14 37978416 Apr 15 2011 15:20:29 +00:00 /bootflash/asr1000rp1-sipspa.03.01.00.S.150-1.S.pkg
15 7541 Apr 15 2011 15:20:29 +00:00 /bootflash/packages.conf
16 4096 Apr 15 2011 15:49:40 +00:00 /bootflash/.rollback_timer
273825792 bytes available (623529984 bytes used)
Router#
thanks
Leo Laohoo
From 3.1.X to 3.13.X?  What about upgrading the bootstrap/ROMmon while you're at it?
Yes i am going to upgrade from 3.1 to 3.13
do you mean that i have to make upgrade to both ios and rommon ? or you mean that issue can be solved by upgrade rommon only ?
Upgrade the IOS and the ROMmon with one reboot.
what is the correct procedure ?
should i use common way to upgrade ios or i need to follow 19 steps mentioned on Cisco website ?
Cisco website shows that 19 steps for routers working in sub package mode, while i think my router is in consolidated mode as it boot directly from the .bin file not the .conf file
what shall i do with insufficient memory space ?
