ASR 9001 console cable
Does the asr 9001 ship with a console cable ? The normal console cable does not seems to work ( used 115200 8N1 and No Flow).
Did any one have difficulties connecting the asr 9001 for the first time ?
4 REPLIES 4
Iulian Vaideanu
Enthusiast
I didn't (have difficulties configuring ASR9001s for the first time), but I remember using 9600, not 115200...
Hi Iulian
Did you use straight through RJ-45 console cable ?
I used an ordinary, blue DB9-to-RJ45, Cisco console cable (I believe it's called rollover cable) that I use for all Cisco devices that I need console access to (and not only those - same cables work for Sun servers as well).
I can't remember if the ASR was packed with its own console cable, but even if it was, I didn't use it.
Hi,   could you connect?  im having the same problem.
