ASR 901 SVI based EoMPLS
wandal
I'm trying to configure SVI based eompls on the 901, and this is the error I get:
interface GigabitEthernet0/5
service instance 202 ethernet
  encapsulation dot1q 202
  rewrite ingress tag pop 1 symmetric
  bridge-domain 202
ASR-901-TEST(config)#int vlan 202
ASR-901-TEST(config-if)#x
ASR-901-TEST(config-if)#xconnect ?
  A.B.C.D  IP address of peer
ASR-901-TEST(config-if)#xconnect 10.20.4.15 15 enc
ASR-901-TEST(config-if)#xconnect 10.20.4.15 15 encapsulation m
ASR-901-TEST(config-if)#xconnect 10.20.4.15 15 encapsulation mpls
The Vl202 a vlan interface - command rejected.
The box is running asr901-universalk9-mz.152-2.SNI code.
I realise you can configure the xconnect on the EFP but we were looking to have multiple EVCs share one bridge domain and do the xconnect on the SVI.
Am I missing something or is this feature not supported on the current code?
Thanks.
5 Replies 5
manib
Hi Alfred,
We don't support xconnect with ASR901 on SVI.  In fact we implemented the CLI error message while attempting to do so.  We support on EVC and port only.
Cheers,
/Mani
Hi Mani,
Thanks for your reply.
Do you know whether there are any plans to have this feature supported in future code or is it a hardware limitation?
Alfred Wandati.
manib
Hi Alfred,
We won't have this on ASR901's radar, and in fact we implemented error message mechanism to alert our
customers.  Its a ASIC and feature limitation on ASR901 alone.
Cheers,
/Mani
Hi Mani,
Thanks for the clarification, we'll just have to work with the xconnect on the EVC.
Alfred Wandati.
gjaimes
Level 5
Level 5
HI guys,
Do you have any news about supporting SVI based EoMPLS on ASR901?
