12-28-2022 06:58 AM - edited 12-28-2022 07:02 AM
After updating the firmware to version 16.12.07 (from version 16.06.04), the translation rules for the ip address pool stopped working.
Static rules work and 1:1 rules work. I don't know how to solve the problem, an example of a broken rule:
ip access-list extended HOSTs_to_Inet
10 permit icmp host 172.24.98.10 any
ip nat pool FW-Inet-IP 129.159.XXX.234 129.159.XXX.234prefix-length 28
ip nat name FW_Inet_Dinamic inside source list HOSTs_to_Inet pool FW-Inet-IP vrf vrf_internet overload
12-30-2022 05:08 AM
did you also upgraded the ROMmon ?
The following table lists the ROMmon releases supported in Cisco IOS XE 16.x.x releases.
Cisco IOS XE Release |
Minimum ROMmon Release Supported for IOS XE |
Recommended ROMmon Release Supported for IOS XE |
16.6.x |
16.6(1r) |
16.6(1r) |
16.7.x |
16.6(1r) |
16.6(1r) |
16.8.x |
16.8(1r) |
16.8(1r) |
16.9.x |
16.9(1r) |
16.9(1r) |
16.10.x |
16.9(1r) |
16.9(1r) |
16.11.x |
16.9(1r) |
16.9(1r) |
16.12.x |
16.9(1r) |
16.12(1r) |
01-02-2023 03:46 AM
What is your ROMMON version,
please check with "show platform"
01-09-2023 12:12 AM
I'm going through the minimum value.
Chassis type: ASR1001-HX
Slot CPLD Version Firmware Version
0 19030215 16.9(4r)
R0 19030215 16.9(4r)
F0 19030215 16.9(4r)
01-09-2023 01:08 AM
Make sure you have backup for running configuration, before upgrading CPLD and FGPA.
01-09-2023 01:24 AM
Tell me, doesn't my version meet the minimum requirements?
01-09-2023 02:33 AM
16.12.X is already end-of-sale. Better you go for 17.3.x with rommon 17.3(1r).
Please check
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/rommon/asr1000-rommon-upg-guide.html
