Hi all,
am trying to acticate broadband license on ASR1001 but the command license feature is not recognized and every time i enter show license command it's not the following:
Index 6 Feature: broadband_4k
Period left: Life time
License Type: Permanent
License State: Active, Not in Use
License Count: 1/0/0 (Active/In-use/Violation)
License Priority: Medium
The current software version installed on the ASR1001 is:
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSAL-M), Version 15.2(4)S, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 23-Jul-12 20:03 by mcpre
IOS XE Version: 03.07.00.S
Cisco IOS-XE software, Copyright (c) 2005-2012 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Elcom-LNS-2 uptime is 51 minutes
Uptime for this control processor is 53 minutes
System returned to ROM by reload
System restarted at 08:20:57 syria Mon Dec 23 2013
System image file is "bootflash:/asr1001-universal.03.07.00.S.152-4.S.bin"
Last reload reason: Reload Command
License Level: adventerprise
License Type: EvalRightToUse
Next reload license Level: adventerprise
cisco ASR1001 (1RU) processor with 1172705K/6147K bytes of memory.
Processor board ID SSI17120EB4
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7741439K bytes of eUSB flash at bootflash:.
i need help to find way to activate the license.
