ASR1002-F SFP and VPN Info needed
ctychan
Beginner
Beginner
Refer to
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/install_upgrade/ASR1000/ASRsov.html
The SFP-GE-T module supports 10/100/1000 speeds.  Does it mean all 1G SFP SPAs and ASR1002-F onbroad 1G SFPs support 10/100/1000 with SFP-GE-T?
Refer to datasheet
http://www.cisco.com/en/US/prod/collateral/routers/ps9343/data_sheet_c78-447652.html
ASR1002-F had up to 1GB VPN performance.  Do anyone know
1) max vpn tunnel support
2) which Cisco vpn client versions are support
B.R.
Charles
Giuseppe Larosa
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Hello Charles,
1)
yes,  I don't see any advice against this. Also because only SFP slots are present:
Yes: 4 Gigabit Ethernet Small Form-Factor  Pluggable (SFP) ports
2) a max data of 4,000 tunnels with the most poweful ESP is reported.
but no specific data for 1002 fixed configuration ASR.
No information about VPN client compatibility.
Hope to help
Giuseppe
