ASR1002X GRE tunnel policy in suspended
datacenter
Hello!
We are facing problems while applying shape policies in our GRE tunnels.
1st problem:
It lets you remove a policy from a interface, but when you try to reenter same line it accepts the command but doesn't apply:
E.g:
ASR1K_DG_RTR_I#sh run int tu211230
interface Tunnel211230
description *** Tunel VPN Principal 30 - Linhares ***
bandwidth 10000
ip vrf forwarding TUNEIS
ip address 10.254.112.29 255.255.255.252
ip mtu 1420
qos pre-classify
keepalive 20 6
cdp enable
tunnel source Loopback30
tunnel destination 10.2.112.30
tunnel vrf TUNEIS
end
ASR1K_DG_RTR_I#conf t
ASR1K_DG_RTR_I(config)#int tu211230
ASR1K_DG_RTR_I(config-if)#service-policy out SHAPE_10000
ASR1K_DG_RTR_I(config-if)#do sh run int tu211230
bandwidth 10000
ip mtu 1420
qos pre-classify
keepalive 20 6
cdp enable
tunnel vrf TUNEIS
end
ASR1K_DG_RTR_I#sh policy-map interface Tunnel211230
ASR1K_DG_RTR_I# ????
2nd problem:
In the interfaces that we already had the policy configured it shows the line, but the policy remains suspended
E.g:
interface Tunnel201230
description *** Tunel VPN Principal 30 - RIB_PRETO ***
bandwidth 920
ip address 10.254.12.29 255.255.255.252
ip mtu 1420
qos pre-classify
keepalive 20 6
cdp enable
tunnel destination 10.2.12.30
tunnel vrf TUNEIS
service-policy output SHAPE_1000_VOZ_100
ASR1K_DG_RTR_I#sh policy-map interface Tunnel201230
Tunnel201230
Service-policy output: SHAPE_1000_VOZ_100
Service policy SHAPE_1000_VOZ_100 is in suspended mode
3rd problem:
Some interfaces are working!
E.g:
interface Tunnel205230
description *** Tunel VPN Principal 30 - Hisa-Escritorio ***
bandwidth 4096
ip address 10.254.52.29 255.255.255.252
ip mtu 1420
qos pre-classify
keepalive 20 6
cdp enable
tunnel destination 10.2.52.30
tunnel vrf TUNEIS
service-policy output SHAPE_4000
ASR1K_DG_RTR_I#sh policy-map int Tunnel205230
Tunnel205230
Service-policy output: SHAPE_4000
Class-map: class-default (match-any)
9744 packets, 467712 bytes
Here are the policies configuration for further reference:
policy-map SHAPE_1000_VOZ_100
class class-default
shape average 920000
service-policy QOS_VOZ_100
policy-map QOS_VOZ_100
class CLASS_QOS_OURO
bandwidth remaining percent 40
class CLASS_QOS_PRATA
bandwidth remaining percent 30
class CLASS_QOS_BRONZE
bandwidth remaining percent 20
class class-default
fair-queue
policy-map SHAPE_4000
class class-default
shape average 3680000
service-policy QOS_PADRAO
policy-map SHAPE_10000
class class-default
shape average 9200000
policy-map QOS_PADRAO
class class-default
fair-queue
Router version:
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(1)S1, RELEASE SOFTWARE (fc1)
cisco ASR1002-X (2RU-X) processor (revision 2KP) with 3743195K/6147K bytes of memory.
Thanks in advance!
Daniel
Hello.
Check which interface is egress per tunnel - show ip cef vrf TUNEIS <tunnel destination>
When service-policy is suspended - it means you are running unsupported configuration.
Diana Karolina Rojas
Hello!
Did you find the root cause of this problem? I have the exactly same issue.
Best Regards,
