Highlighted
Beginner
ASR1004 HW design
All ,
I have requirement , would be great if you can share your experience and knowledge
Requirement
1 x   CASR1004-40G-NB
4 x   SPA-10X1GE-V2 (10 port Ethernet Module)
When Tried to build the Bill of material in cisco  CCW tool ,  finding an error  while adding  double height SPAs  (SPA-10X1GE-V2 ) , the below combination used.
  • ASR1000-SIP40    -     2*  SPA-10X1GE-V2 ( double height SPAs)
  • ASR1000-SIP40-NB1   - 2 * SPA-10X1GE-V2 ( double height SPAs)
The router model asr 1004 supporting only two SIP
ASR1000-SIP40 or ASR1000-SIP40-NB1
SIP slot bundle  ASR1000-SIP40-NB0
the problem is   ASR1000-SIP40-NB0 is allowing only to add  SPA-1X10GE, which I can get only 1* 10g SFP .
would like to know  4*  SPA-10X1GE-V2  works in practical , want to order two SIPs  ASR1000-SIP40 &  ASR1000-SIP40-NB1 where It is supporting  40 SFP modules with 1G capacity?
