ASR1006 IOS XE/Firmware upgrade - Do I have to upgrade Firmware?
MattHunt1980
Beginner
Beginner
This question regards whether or not I have to upgrade the firmware on an ASR1006 device, when upgrading IOS version.
Device is currently running IOS XE - 03.04.05.S (Version 15.1(3)S5) - asr1000rp1-advipservicesk9.03.04.05.S.151-3.S5.bin
I am upgrading the IOS version to 03.17.03.S (15.6(1)S3) - asr1000rp1-advipservicesk9.03.17.03.S.156-1.S3-std.bin. So the IOS version is witihin the same Major release.
*My installed modules are as follows:
Chassis type: ASR1006
Slot      Type                State                 Insert time (ago)
0         ASR1000-SIP10       ok                    3y21w
 0/0      SPA-1X10GE-L-V2     ok                    3y21w
1         ASR1000-SIP10       ok                    3y21w
 1/0      SPA-1X10GE-L-V2     ok                    3y21w
2         ASR1000-SIP10       ok                    3y21w
 2/0      SPA-10X1GE-V2       ok                    3y21w
R0        ASR1000-RP1         ok, active            3y21w
R1        ASR1000-RP1         ok, standby           3y21w
F0        ASR1000-ESP20       ok, standby           3y21w
F1        ASR1000-ESP20       ok, active            3y21w
P0        ASR1006-PWR-AC      ok                    3y21w
P1        ASR1006-PWR-AC      ok                    3y21w
Slot      CPLD Version        Firmware Version
0         07091401            12.2(33r)XNB
1         07091401            12.2(33r)XNB
2         07091401            12.2(33r)XNB
R0        07062111            12.2(33r)XNB
R1        07062111            12.2(33r)XNB
F0        08041102            12.2(33r)XNB
F1        08041102            12.2(33r)XNB
Can I use the same firmware or will I have to upgrade. I am a little confused by the release notes and they are not very intuative.
I would rather NOT upgrade the firmware if I do not have to.  Also what relation does the firmware have against the IOS version, do some IOS features require the firmware to be upgraded.
I have researched the following for the details:
http://www.cisco.com/c/en/us/td/docs/ios/ios_xe/3/release/notes/asr1k_rn_3s_rel_notes/asr1k_rn_3s_sys_req.html
Iulian Vaideanu
Enthusiast
Enthusiast
According to tables 6 and 7 here, IOS XE 3.4S and 3.17S have the same ROMMON requirements for your configuration:
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/release/notes/asr1k_rn_rel_notes/asr1k_rn_sys_req.html#19706
The minimums there, however, are already newer than what you're running and, while XNB may still work with 3.4S, it may not with 3.17S.
I'd do the upgrade - one thing I experienced with too old ROMMON vs. too new IOS is that the IOS image checksum wouldn't be validated at boot time (and therefore would be considered unusable for booting)...
Recognize Your Peers
