ASR1k - L3 Etherchannel
TelesEC
Hi all,
I have a pair of ASR1Ks that are interconnected via an L3 Etherchannel with two members.
A few days ago I tried to attach two members to the Etherchannel, but the two new members remain in 'suspended'.
There is no limitation of members (lacp max-bundle), does anyone have any idea? There is nothing 'exotic' about the Etherchannel configuration.
channel-group 7 mode active <-> channel-group 7 mode passive
If I don't use LACP, the Etherchannel (mode ON) works without problem with all 4 members, but when I activate LACP, only two members are active and the other two in 'suspended'.
Thanks in advance.
TelesEC
After a shut/noshut, the situation changed and it works.
TelesEC
Can you show the output of the interfaces that are bundled vs the ones that are not and the command "show etherchannel summary"
-David
Thank you for your response David.
According to my colleague who is physically in the data center, a shut/no shut of the Po apparently solved the problem.
As I couldn't find the option to delete the post, I replied to myself.
Thanks again!!!
