Beginner
ASR901 does not take service-policy output command
We are in progress rolling out a couple of ASR901 as WAN CPE routers.
We are planning to use HQF (Hierachical QoS Framework).
Have a pretty basic parent - child config (see below). When I apply the policy on the WAN facing interface nothing actually happens. The policy is not applied and I do not get any error message.
Tried same polilcy on other router platforms, and it works OK there.
What is the problem?
class-map   match-any CM-REALTIME
match dscp ef
match dscp cs4
match dscp cs5
class-map match-any CM-CONTROL
match dscp cs6
match dscp cs3
match dscp cs2
class-map match-any   CM-CRITICAL
match dscp af41 af42 af43
match dscp af31 af32 af33
class-map CM-SCAVENGER
match dscp cs1
policy-map PM-CE-OUT-CHILD
class CM-REALTIME
priority percent 33
class CM-CONTROL
bandwidth percent 7
class CM-CRITICAL
bandwidth percent 35
random-detect dscp-based
random-detect dscp af31 50 64
random-detect dscp af32 45 64
random-detect dscp af33 40 64
random-detect dscp af41 50 64
random-detect dscp af42 45 64
random-detect dscp af43 40 64
class CM-SCAVENGER
bandwidth percent 1
class class-default
bandwidth percent 24
random-detect dscp default 100   128
policy-map PM-CE-OUT-10M
class class-default
shape average 10m
service-policy PM-CE-OUT-CHILD
int ten0/1
service-policy output   PM-CE-OUT-10M
#show run int ten0/1
interface TenGigabitEthernet0/1
description UPLINK
no ip address
No policy shows up !
Everyone's tags (5)
Content for Community-Ad
August's Community Spotlight Awards
