Highlighted
Beginner
ASR903_RP3_400 Supports for PBR
I want to implement PBR on ASR903_RP3_400. during my researches I found this link which says the feature is not supported on RP3. It this correct?
https://www.experts-exchange.com/questions/29112865/ASR-903-PBR.html
Thank you
Peyman
1 ACCEPTED SOLUTION
Highlighted
HI
In the document, you sent it is mentioned the RSP3 does not support PBR
I also found document for Train 16 and This restriction is there:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_pi/configuration/xe-3s/asr903/16-12-1/b-iri-xe-16-12-asr903/m-iri-pbr-900.html
Thank you  for help and support
5 REPLIES 5
Highlighted
VIP Mentor
Sometime hard to say, since cisco some features will be support based on the model.
right option is : check feature navigator or contact local Cisco SE to suggest better.
https://cfnng.cisco.com/
BB
*** Rate All Helpful Responses ***
Highlighted
Thank you for the update,
FN does not have information about ASR903
Highlighted
VIP Advocate
 - https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_pi/configuration/xe-3s/asr903/iri-xe-3s-asr903-book/iri-xe-3s-asr903-book_chapter_010.html#GUID-87FE3531-E375-468B-A8AF-49C58120A767
 Following this  guide , I would presume that it should, I would suggest to follow the configuration guidelines and check.
 M.
Highlighted
Thank you for the update, I will check this
Highlighted
HI
