ASR920 sub interface
mkouame17
Level 2
Level 2
Dear Guys,
We just received a new ASR920 and I try to create a sub interface but I can't.
After some research I find that we have to use a bridge domain.
For test purpose I connect my laptop to the router in peer to peer mode.
And I create bridge domain (see configuration below),I try to ping from my PC to the ASR920 but it doesn't work.
interface GigabitEthernet0/0/0
 no ip address
 negotiation auto
 service instance 1 ethernet
  encapsulation dot1q 412
  bridge-domain 412
interface BDI412
 ip address 10.70.12.1 255.255.255.0
end
!!!!!This is the show run of the router
no aaa new-model
redundancy
transceiver type all
 monitoring
 no ip address
 negotiation auto
  encapsulation dot1q 410
  bridge-domain 410
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 negotiation auto
interface GigabitEthernet0/0/3
 no ip address
 negotiation auto
interface GigabitEthernet0/0/4
 no ip address
 media-type auto-select
 negotiation auto
interface GigabitEthernet0/0/5
 no ip address
 negotiation auto
interface GigabitEthernet0/0/6
 no ip address
 negotiation auto
interface GigabitEthernet0/0/7
 no ip address
 negotiation auto
interface GigabitEthernet0/0/8
 no ip address
 negotiation auto
interface GigabitEthernet0/0/9
 no ip address
 negotiation auto
interface GigabitEthernet0/0/10
 no ip address
 negotiation auto
interface GigabitEthernet0/0/11
 no ip address
 negotiation auto
interface TenGigabitEthernet0/0/12
 no ip address
interface TenGigabitEthernet0/0/13
 no ip address
 vrf forwarding Mgmt-intf
 no ip address
 negotiation auto
interface BDI412
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
control-plane
line con 0
 exec-timeout 0 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login
Router#ping 10.70.12.1
Sending 5, 100-byte ICMP Echos to 10.70.12.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
!! 10.70.12.5 is my PC @ip
Router#ping 10.70.12.5
Sending 5, 100-byte ICMP Echos to 10.70.12.5, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Thank for your help
Hi guy,
The issue was on the switch side. I used a new switch and it works fine.
luis_cordova
Hi @luis_cordova
I already see this topic and as you can see it is the same config I apply here also.
I try to do router in sitck with this router.
  bridge-domain 412
service instance 2 ethernet
  encapsulation dot1q 413
  bridge-domain 413
end
interface BDI412
no sh
exit
interface BDI413
ip address 10.70.13.1 255.255.255.0
no sh
exit
But it doesn't work. The interfaces are up but there is no connectivity.
Hi guy,
