08-08-2006 06:47 AM - edited 03-03-2019 01:35 PM
Is there a command or method that will provide the ability to permanantly write/store information within the device, such as the client asset number/ID, to the following router platforms; 1841, 3845, 720xVXR. NB: Although a possible solution is to write this information to the configuration file, as information only text, it is NOT considered acceptable approach for the project.
08-08-2006 07:59 AM
None that I know of. Anything in memory can be overwritten.
08-08-2006 10:24 AM
Not that I know of...Ciscoworks config job to all the devices;but that would write it to the config.
08-08-2006 11:10 AM
how about MKDIR on the flash where the file name you create is the asset number of the router.
