Highlighted
Beginner
Asynchronous RS-232 Traffic Over UDP
I was testing this protocol and BSTUN as method to transport several RS232 streams over IP to a several destinations.
Now i'm testing UDPTN and I found a little problem.
I must implement a multicast UDP transport in any DUPLEX MODE, but the autocommand line and the UDPTN mechanism have an issue.
For some reason this method was designed in only one way.
The route who transmit the strem :
LOCAL R236
Serial 0/1
  physical-layer async
line 2
     autocommand udptn 239.50.0.1 /transmit
The router/s that receive the strem:
REMOTE R237
Serial 0/1
line 2
     autocommand udptn 239.50.0.1 /receive
This works great, but the RS232 port is not a one way line, It must TRANSMIT and RECEIVE. Not only transmit from a local to a remote, both operation must work
So I think set-up to differents Multicast address, one for the transmiters and other for the receivers. It can be done too if we change the TX/RX ports.
I Must set up the autocommand UDPTN like this:
LOCAL R236
Line 2
     autocommand UDPTN 239.50.0.1 /transmit
     autocommand UDPTN 239.50.0.2 /receive
REMOTE ROUTERS
Line X
     autocommand UDPTN 239.50.0.1 /receive
     autocommand UDPTN 239.50.0.2 /transmit
How i can set-up that autocommand ???
Best Regards
Frank
0 REPLIES 0
Content for Community-Ad
