09-23-2011 04:04 AM - edited 03-04-2019 01:43 PM
I have been advised by my service provider that to do ATM IMA I need an AIM-ATM and a VWIC2-2MFT-T1/E1 card, and that IMA is not support on the VWCI2-2MFT-G703 card.
Can anyone confirm if this is true ?
09-27-2011 07:09 AM
Lee,
This is correct, please see:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/Cisco_Router_Guide.pdf
Bill
09-27-2011 07:50 AM
Hi Bill,
Thanks for the link, but could you please advise where in that document it states that the VWIC2-2MFT-G703 does not work with IMA, I can only see that it is not available to be purchased in a bundle with an AIM-ATM, but that in itself does not mean it won't work.
Lee
09-27-2011 08:27 AM
Lee,
If you take a look at the VWIC2-2MFT2-G703, it shows a list of supported features, ATM IMA is not one of them hence it is not supported. Another indicator is that it is not listed as a bundle. When looking at these documents they list what is supported.
Bill
09-27-2011 08:45 AM
Hi Bill,
Do you have any other document that lists the supported features, I don't see in your previous link where it states that the VWIC2-2MFT-T1/E1 supports ATM-IMA.
Also, the data sheet for the VWIC2 cards states the following which seems to indicate to me that all capabilities in the T1/E1 card are supported in the G703 card.
T1/E1 data---The Cisco 1- and 2- port T1/E1 MFT VWIC2 versions act as a WIC, supporting T1, fractional T1, E1, (including structured G.703 with G.704 framing), fractional E1, and E1structured G.703 applications. To simplify remote management, these MFT VWIC2 cards integrate a fully managed DSU/CSU for T1 deployments and a fully managed DSU for E1 deployments.
• E1/G.703 data---The Cisco 1- and 2- port G.703 MFT VWIC2 versions act as a WIC, supporting T1, fractional T1, E1 (including structured G.703 with G.704 framing), fractional E1, and unstructured E1 (G.703) applications. To simplify remote management, the G.703 version includes a fully managed DSU. The G.703 versions also support all the capabilities on the T1/E1 versions.
09-27-2011 11:56 AM
Lee,
The VWIC2-2MFT-T1/E are part of the bundle AIM-ATM-4T1/E1 which replaced the older IMA modules hence it is
supported.
The pdf file below shows which modules are supported per platform
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf
EOS has been announced on the bundles
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps5855/eol_c51_633170.html
I do not see any documentation that specifically states IMA is supported on the VWIC2-2MFT2-G703.
Generally customers implement IMA on one of the bundles. I went back and looked at some old cases in the database and found a couple customers have implemented IMA successfully on G703.
