ATM Mode on 2600 router
pavloviandog
I am trying to configure a newly installed 1MFT t1 WIC card for ATM communication. The router is a 2651 version 12.2. I have issued the mode atm, framing esf and linecode b8zs. But mode atm is not shown in the show run command. Have I missed a step?
2651#show run
Building configuration...
Current configuration : 956 bytes
version 12.2
ip subnet-zero
ip wccp web-cache
controller T1 0/1
framing esf
linecode b8zs
--More--
Any advice would be greatly appreciated...
I did a quick search and it shows as '1-port RJ-48 multiflex trunk VWICT1'
It's not an ATM module so the mode you need to use is T1, not ATM.
http://www.cisco.com/en/US/prod/collateral/routers/ps274/product_data_sheet09186a0080091b9c_ps259_Products_Data_Sheet.html
8 Replies 8
Edison Ortiz
It's the WIC card present when issuing 'show diag' or 'show inventory'?
Perhaps your IOS code does not support the module.
Please refer to the WIC documentation:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a0080088753.html
Cisco 2600 Series, 3660
AIM-ATM: 12.2(2)XA/12.2.4T
AIM-VOICE-30: 12.2(2)XB/12.2.8T
AIM-ATM-VOICE-30: 12.2(2)XB/12.2.8T
and Feature set:
Any Cisco IOS "Plus" or "SP Services" Feature Sets
I have a sneaking suspicion I don't have a compatable router. I do not have the choice of using AIM. Below is the version, and the show diag shows the T1 controller (see below)
2651#show ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(8)T5,  RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 21-Jun-02 08:50 by ccai
Image text-base: 0x80008074, data-base: 0x80A2BD40
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
2651 uptime is 3 hours, 35 minutes
System image file is "flash:c2600-i-mz.122-8.T5.bin"
cisco 2651XM (MPC860P) processor (revision 0x100) with 60416K/5120K bytes of memory.
Processor board ID JAD06400FP7 (3829963429)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 Channelized T1/PRI port(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
2651#show diag
Slot 0:
        C2651XM 2FE Mainboard Port adapter, 4 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware Revision        : 1.0
        PCB Serial Number        : JAD06400FP7 (3829963429)
        Part Number              : 73-7756-02
        RMA History              : 00
        RMA Number               : 0-0-0-0
        Board Revision           : A0
        Deviation Number         : 0-0
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 03 6F 41 01 00 C1 18 4A 41 44 30 36 34
          0x10: 30 30 46 50 37 20 28 33 38 32 39 39 36 33 34 32
          0x20: 39 29 82 49 1E 4C 02 04 00 81 00 00 00 00 42 41
          0x30: 30 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        FT1
        Hardware revision 1.3           Board revision E0
        Serial number     29034259      Part number    800-03279-04
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 2
          0x20: 02 11 01 03 01 BB 07 13 50 0C CF 04 00 00 00 00
          0x30: 70 00 00 00 02 09 30 01 FF FF FF FF FF FF FF FF
        WIC Slot 1:
        T1 (1 port) WAN daughter card
        Hardware revision 1.0           Board revision D0
        Serial number     30306616      Part number    800-03568-03
        Connector type    PCI
        EEPROM format version 1
          0x20: 01 20 01 00 01 CE 71 38 50 0D F0 03 00 00 00 00
          0x30: 68 00 00 00 03 05 30 00 FF FF FF FF FF FF FF FF
Slot 1:
        Unknown (type 216) Port adapter
        Port adapter is disabled
        Top Assy. Part Number    : 800-04797-01
        Board Revision           : G0
        Fab Version              : 05
        PCB Serial Number        : JAE0713081D
        RMA Test History         : 00
        RMA History              : 00
          0x00: 04 FF 40 00 D8 41 01 00 C0 46 03 20 00 12 BD 01
          0x10: 42 47 30 80 00 00 00 00 02 05 C1 8B 4A 41 45 30
          0x20: 37 31 33 30 38 31 44 03 00 81 00 00 00 00 04 00
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
on a XM router it should be support per the documentation. What does 'show inventory' displays?
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_m3.html#wp1370241
Can you physically view the part number?
Edison
I don't have show inventory, I have show interfaces, which shows 1 serial port and two FastEthernet ports, but not the T1.
The part number is listed as 800-03568-03 from the show diag command.
Well I guess that is why I was unable to set the mode to ATM. Thanks Edison.
One last thing... it only allows ATM as the mode of choice but doesn't list the mode from the show run.
2651#config t
Enter configuration commands, one per line.  End with CNTL/Z.
2651(config)#controller t1 0/1
2651(config-controller)#mode ?
  atm  Configure ATM mode
2651(config-controller)#mode atm ?
2651# show run
controller T1 0/1
framing esf
linecode b8zs
--More--
Yes, the CLI won't prevent you from having the choice but the configuration won't take as the card itself isn't an ATM.
