ATM T-1 Card with Serial T-1's
spfeffer
I know this is a very naive and novice question, but I have 2 point to point T-1's that I would like to connect to the following card in a 7206 VXR:
PA-A3-8T1IMA=
Is there any confiration that will allow me to utilize this card with serial T-1's?
paolo bevilacqua
You can use that card, but on the other side of the circuits you will need another ATM IMA interface of some kind. You cannot connect ATM IMA to non-IMA equipment directly, and there are no workarounds to that.
paolo bevilacqua
That's what I thought...hmmmm...I'll have to dig around in the parts drawer and see what I can find. Thanks.
You're welcome, please remember to rate useful posts.
