Authenticate my switch using ISE server
schadracpierre
Hello everyone,
I am trying to configure my switch so everyone who has an account on my AD can log in using ISE authentification server. I use DMVPN to my spokes with the Hub. All my spoke routers and hub devices are well configured and can use my ISE to log except my switches behind my spokes routers. Here is the configuration in one switch:
SPOKE-3-CORE#sh run
Building configuration...
Current configuration : 3139 bytes
! Last configuration change at 13:58:14 UTC Tue Sep 19 2023 by test
version 15.2
service compress-config
hostname SPOKE-3-CORE
boot-start-marker
boot-end-marker
enable secret 5 $1$f7H2$UCn.F1lPhqTRgQeH8wJts.
username test privilege 15 secret 5 $1$P1pM$xKL/W5qLN.ZWbtOqFZsCC1
aaa new-model
aaa group server radius ISE
server 10.10.10.12
ip radius source-interface Loopback10
aaa authentication login default local group ISE
aaa authentication dot1x default group ISE
aaa authorization console
aaa authorization exec default local group ISE
aaa authorization network default group ISE
aaa accounting update newinfo
aaa accounting dot1x default start-stop group ISE
aaa accounting exec default start-stop group ISE
aaa server radius dynamic-author
client 10.10.10.12 server-key C!sc0
aaa session-id common
ip dhcp excluded-address 10.10.13.9 10.10.13.12
ip dhcp excluded-address 10.10.13.17 10.10.13.20
ip dhcp excluded-address 10.10.13.25 10.10.13.28
ip dhcp pool DATA
network 10.10.13.8 255.255.255.248
default-router 10.10.13.9
domain-name techplus.edu.org
dns-server 10.10.10.10 8.8.8.8
option 150 ip 10.10.13.9
lease 0 8
ip dhcp pool VoIP
network 10.10.13.16 255.255.255.248
default-router 10.10.13.17
option 150 ip 10.10.13.17
lease 0 8
ip dhcp pool IT
network 10.10.13.24 255.255.255.248
default-router 10.10.13.25
option 150 ip 10.10.13.25
lease 0 8
no ip domain-lookup
ip domain-name techplus.edu.org
ip cef
no ipv6 cef
spanning-tree mode pvst
ip address 10.3.255.9 255.255.255.255
interface Ethernet0/0
description "Interface towards the router"
no switchport
ip address 10.10.13.2 255.255.255.252
interface Ethernet0/1
switchport access vlan 10
switchport mode access
interface Ethernet0/2
switchport access vlan 20
interface Ethernet0/3
switchport access vlan 30
interface Vlan10
ip address 10.10.13.9 255.255.255.248
interface Vlan20
ip address 10.10.13.17 255.255.255.248
interface Vlan30
ip address 10.10.13.25 255.255.255.248
router eigrp 10
network 10.0.0.0 255.255.0.0
network 192.168.1.0 255.255.255.0
ip forward-protocol nd
ip http server
ip route 0.0.0.0 0.0.0.0 10.10.13.1
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 30 tries 3
radius server ISE
address ipv4 10.10.10.12 auth-port 1812 acct-port 1813
key C!sc0
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
monitor session 1 source interface Et0/0
end
Please provide any thoughts you think might help.
TIA
17 Replies 17
Hello
@schadracpierre wrote:
*Sep 20 23:24:07.693: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.10.10.12:1812,1813 is not responding.
*Sep 20 23:24:07.693: %RADIUS-4-RADIUS_ALIVE: RADIUS server 10.10.10.12:1812,1813 is being marked alive.
% Authentication failed
But I used to have that on other equipment I used to log as well. just to let you know.
Got to ask, is the ISE then compatible with this make of switch?
Kind Regards
Paul
For that, I don't know. I am using a Cisco IOL virtual switch.
schadracpierre
I found the error and fixed it. the issue was the bandwidth on the tunnel.
Changed the source
interface to ethernet 0/0
and under the tunnel interface, I changed the bandwidth to 85k
interface tunnel 10
bandwidth 85000
