Auto-failover mode
Yogeshraje
Hi All, I want to configure data, voice traffic on one link and cctv traffic on the second link with auto-failover mode. If anyone could help.
balaji.bandi
There is good example start with : (and tweak as you like)
https://www.balajibandi.com/?p=1643
BB
Hi Balaji, Will check and let yu know , Thank you.
Joseph W. Doherty
Since you want to mix data and VoIP on one link, and in a link failure situation, might mix data, VoIP and CCTV, I would think QoS is a "must".  If so, and especially in the case of a link failure, where all traffic is using one link, have you considered just using QoS and allowing all flow kinds to use both links?
